How To Tune an Evo
Old Aug 22, 2008 | 11:27 AM
  #526
evo8kid-VIP's Avatar
need reflash map
i have evrything to do a reflash looking for a good program...anyone have one ???doing a 2004 evo8........if anyone has any help send downloads to will-vipperformance@hotmail.com
Old Aug 22, 2008 | 11:52 AM
  #527
TouringBubble's Avatar
Seriously man ... read. You've posted something in at least 2 different threads that give you the EXACT info you are looking for.
Old Aug 22, 2008 | 11:58 AM
  #528
hey i just downloaded ecuflash 1.39v is that a good one???
Old Aug 22, 2008 | 11:59 AM
  #529
o and sorry i wasnt payin attion i am running a shop right now im going back and forth to comp. to projects sorry man
Old Aug 22, 2008 | 12:11 PM
  #530
Yes, that's exactly what you need.
Old Aug 22, 2008 | 06:05 PM
  #531
Chabada15's Avatar
your gunna tune the ecu with a UTEC in the car as well...thats just redundant
Old Aug 22, 2008 | 07:11 PM
  #532
GTR2009's Avatar
where did you get that ? on ecuflash.org website the latest version is 1.35
Old Aug 25, 2008 | 10:41 AM
  #533
nestoledo's Avatar
it already manages to fit to the injectors 740cc, now the problem is that when putting D the AFR lowers from 14,7 to 10.5
Old Aug 25, 2008 | 11:02 AM
  #534
Chabada15's Avatar
i have no idea what that means...is your car automatic?
Old Aug 25, 2008 | 11:14 AM
  #535
nestoledo's Avatar
yes it is a automatic 2003 lancer ES turboed
Old Aug 25, 2008 | 11:57 AM
  #536
Chabada15's Avatar
i wouldnt even know where to begin in tuning that...you realize that tranny is gunna be shot in no time right?...like...destroyed, it may be better for you to leave the boost low
Old Aug 25, 2008 | 07:56 PM
  #537
RyeLou's Avatar
I know someone mentioned before, but what about tips for tuning at idle? I know there is a big thread out there about the Stepper Table and throttle hang, so I suppose I could read that one too.
I'm having an issue right now with my throttle hanging at 4K only after a WOT run. It will hang there until I shift to a higher gear and make the car drop the RPMs. Once it hits 3500 it falls off like normal. To spare a very long post, I've tested almost everything I can think of mechanical that could cause it. (throttle cable, throttle body, TPS, IAC, vac. leak, etc.) The only thing that made this go away was disconnecting the harness to the IAC. I read this thread in hopes that I would run across something that could help me. I didn't think I did until today.
Now I don't know what the stepper table looks like (and I suppose I should read that other thread...) but my problem happened after it was retuned after adding the cams and LICP. With those mods, I assume I would move further to the right as the engine load would go up, correct? Is it possible that the steps in those cells could be causing this? On a scanner the only thing that reads out of the ordinary is the steps. They hold at about 160. TPS shows 0, and I've verified it by actually looking at the TB to make sure it's closed. I've switched IACs with someone else, and the problem didn't go away with the other one. Only having it unplugged fixed the problem. I don't know exactly how the idle/stepper table deal works, so I was reading this thread to try to figure it out.
I'm waiting to get my laptop back from my friend, so I can't provide any logs at this time I did have my tuner email me my current .hex file, so I could forward it to someone so they could see what it looked like. If someone is willing to help me, send me a PM with your email address and I'll have it on the way!
Sorry for the long post sort of off topic An idle section to the first post(s) would be great. Something to help for those of us who add cams. I've noticed there are seperate idle table for with and without the A/C running. I idle great with the A/C off, but with the A/C on it bounces between 1000 RPM and 2000 RPM...I need to work on that!
Great read though. Spread it out over last night, today at work and this evening and I'm sure I'll be going through a majority of it again!
Old Aug 25, 2008 | 09:16 PM
  #538
khara's Avatar
Nice work
Old Sep 11, 2008 | 12:13 PM
  #539
SpeedJunkyz's Avatar
Awesome find. I have all the gear, and I will continue the research and reading. Thanks
Old Sep 11, 2008 | 05:35 PM
  #540
Are these guys still around....I couldn't find them.
razolab & touring bubble
SJ
