How To Tune an Evo
Old Jul 11, 2011 | 04:40 PM
  #736
Raptord's Avatar
No, raising timing to 11 or 12 when you already knock at 10 is going to cause even more knock. In that instance you need to lower timing to get rid of knock.
Old Jul 11, 2011 | 09:37 PM
  #737
mitsevolution's Avatar
cool
Old Jul 26, 2011 | 07:50 PM
  #738
Blitz's Avatar
Originally Posted by nj1266
Stupid question probably but how do I see my log in this format? What program is this a screenshot from? If EvoScan, how do I get it to show my log like this?
Old Jul 26, 2011 | 07:56 PM
  #739
Boosted Tuning's Avatar
Originally Posted by Blitz
How can I see my log in this format? What program is this a screenshot from? Seems very useful.
Innovate Logworks program, using a ECUflash definitions/patch.
Evoscan also has a maptracing feature. It doesnt work for some people, but I have always had good luck with it.
Old Jul 30, 2011 | 11:08 PM
  #740
GBeZeFromNAPeZe's Avatar
Is it possible to open more than one log and see averages with EvoScan map tracer? I can't see any way to do it, but the author of this sticky seems to imply you can at one point. Is it possible with Logworks, since that's what he was using?
Old Jul 30, 2011 | 11:37 PM
  #741
The OP used Logworks for tuning, AFAIK.
Old Jul 31, 2011 | 01:13 PM
  #742
slatermvp's Avatar
how do you use maptracing?? I know dumb question.
Old Jul 31, 2011 | 01:21 PM
  #743
In EvoScan, go to the "Graphs & Maptracee", then "Maptracer - AFR & timing vs load". Load your log.
Then right click on the lower grayed box, and select "load ROM", then pick your ROM.
Old Aug 1, 2011 | 12:45 PM
  #744
slatermvp's Avatar
sweet thanks bro
Old Aug 5, 2011 | 08:50 PM
  #745
Evo MR IX Fritz's Avatar
this was a beast of a write up.. +1 for u my friend.. very good info just what i was looking for. now i have abetter idea how the evo is tuned.(former flashpro user lol)
Old Sep 1, 2011 | 12:56 AM
  #746
907dsm's Avatar
Can anyone for the life of me please load to me?? I watched the intro to ecuflash video's on youtube, and from the video I got that anything above 100% the turbo is spooling up?? And anything below 100 turbo isn't spooled?? I also got from the video it's basically airflow entering the engine?? Basically I'm looking for a simplier definition for my small brain. Any input would be great.
Thanks Alex
Old Sep 1, 2011 | 07:29 AM
  #747
Raptord's Avatar
Yes, load is pretty much how much airflow is going through the MAF. In my case I start getting positive boost pressure around 90 load, but usually above 100 load is positive pressure.
Old Sep 1, 2011 | 09:41 AM
  #748
chetrickerman's Avatar
Veteran: Army
exactly. the more air that the MAF reads, the more load that the ECU interprets.
make sense?
Old Sep 1, 2011 | 04:10 PM
  #749
907dsm's Avatar
Thank you very much for you reply.
make sense?
So what's the max it interprets?? Can I change it to a different scaling besides load???
Thank you Alex
Old Sep 1, 2011 | 04:28 PM
  #750
charlie.tunah's Avatar
you want it to read load so it correlates to your maps. I guess if you really wanted, it could all be customized. But in a sense, 100 load is close to 0psig, 200 load is close to 14.7psig and 300 load is close to 29.4psig at sea level. But there are also alot of other factors that affect how the ECU calcs load, so those boost/load numbers wont always be spot on with the stock MAF setup.
The raw output of the MAF is hz. hz, temp, baro, plus some more stuff (??) is where the load comes from. Unless youre running speed density
