Let's see your fully tuned timing maps
Old Jun 19, 2017 | 09:33 AM
  #2701
ronaldo9's Avatar
What load factor are you using? 1.3?1.4? And is the number aligned from your rom in ecuflash with the calculation in evoscan?
Old Jun 19, 2017 | 01:29 PM
  #2702
EvilDSM97's Avatar
I am using 1.4 load factor.
Made sure to align my rom in evoscan using my last log, still showing in the 310 load cells.
Did another couple of pulls with no luck. Tried adding some more timing in the 310/320 load cells, and still peaking at 9 degree's. I'm quite confused at this point.
Old Jun 19, 2017 | 04:52 PM
  #2703
mines5's Avatar
Using the same load factor in the rom and evoscan both?
Are you revving 8000 + .. Logging 2byte rpm & load ?
Old Jun 19, 2017 | 05:30 PM
  #2704
EvilDSM97's Avatar
As far as load factor yes, set in both evoscan and in rom.
Not using 2 byte RPM, however. I rev to 7300 typically, limit is set at 7500.
Old Jun 20, 2017 | 05:42 AM
  #2705
ronaldo9's Avatar
What if you set the map to 8 degrees, will the log show 8 degrees for that load. I'm curious if the ecu is pulling timing regardless of what you have on the map. Also is your low octane ignition map set to the same values as the high octane map? Is this an evo 8 or 9?
Old Jun 20, 2017 | 06:28 AM
  #2706
mines5's Avatar
Thinking the same. Check all the ignition timing trim maps.
Old Jun 20, 2017 | 06:41 AM
  #2707
2winscroll's Avatar
are you getting any knock? you need to log that and see.
Old Jun 20, 2017 | 06:57 AM
  #2708
2winscroll's Avatar
If your not getting any knock, then in ECU flash check to make sure the load table is set to reference the Omni 4 bar sensor. I know the tephra 9653 rom labeled Omni 4 bar is configured wrong. You actually have to go in and change the load scale from kalvico 3.5 bar to Omni 4 bar. Can't remember if it was the load table that was wrong or the sd table. Also check your psi table for boost control. There are several places in ECU flash that reference the Omni 4 bar sensor scaling. If your using the ECU for boost control be careful if you change these over to Omni 4 bar as they will change your boost level.
That's assuming your running the Omni 4 bar sensor. I know it's mixed up on that 9653 sd rom that's labeled for the 4 bar.
Old Jun 20, 2017 | 07:50 AM
  #2709
EvilDSM97's Avatar
This is an Evo 8.
I actually think my low octane ignition map is set to 9 degrees in those areas, I have to verify that when I get home when I have my laptop in front of me but I'm fairly certain. Is it possible for the ecu resort to the low map although there is no knock detected in the logs?
Old Jun 20, 2017 | 09:27 AM
  #2710
EvilDSM97's Avatar
I'm using Tephra's 94171715 SD rom (with Omni 4 bar) but I will double check what you meantioned just in case. Also, not getting any knock in any of my recent logs. It did log 2 counts of knock when we had a 11.8 lean spot in the tune at 6500, but we richened that area up and air fuels now stay a solid 11.5 from the full boost area of 5500 right up until 7300-7500 with no counts of knock at all. Ronaldo may be onto something about my low octane timing map, but why would the car resort to that map without any knock? 🤔
Old Jun 20, 2017 | 10:42 AM
  #2711
2winscroll's Avatar
I can't remember which rom was wrong it may have been 9417. I was on that rom but I switched to 9653. I had the same problem and that was the issue. You did verify your evoscan definition is correct I assume.
Old Jun 20, 2017 | 11:37 AM
  #2712
ronaldo9's Avatar
Do you log knock voltage also?
Old Jun 20, 2017 | 04:36 PM
  #2713
EvilDSM97's Avatar
Not up to this point
Old Jun 20, 2017 | 04:48 PM
  #2714
EvilDSM97's Avatar
I'm finally home from work in front of my laptop. Figured I'd screenshot some of my settings. (Also added a shot of low octane timing map for good measure)
Let me know if anything jumps out at anyone that may be wrong. By the way I really do appreciate everyone taking the time to try to help me out with this thus far!
Old Jun 20, 2017 | 06:39 PM
  #2715
2winscroll's Avatar
In evoscan post 2702, I see you are using Omni kpa load, ECU load will be different since it is modified by map sensor VE table. For instance when your map sensor reads 350 load, your ECU load will be 370 ECU load. I can't see anything else wrong tho
In the drop down for the load axis you need to choose load 1 byte. That should put you in the 330 column
