Let's see your fully tuned timing maps
Old Aug 8, 2011 | 08:19 PM
  #1201
Ian0611's Avatar
Originally Posted by dparrish
I'd like to see it. I have a gear dependent WGDC map that I've spent a bit of time on, but I'd like to see what it's like compared to some others.
Anybody else curious. If one or two more says yes, I'll go ahead and start it.
Originally Posted by wizzo 8
I tend to do that to people sometimes
You inspire me!!
Old Aug 12, 2011 | 07:36 PM
  #1202
GregM's Avatar
I'm running 26psi tapering to 24psi, but my timing at 7000rpm is only 9 degrees. Is it best to taper the boost more and run more timing up top?
Old Aug 12, 2011 | 07:46 PM
  #1203
Ian0611's Avatar
It depends on the setup. On a stock turbo you're probably starting to run out of the efficeincy range of the turbo at 24psi@7000 and you're basically just blowing hot air at that point. In that case the answer would be yes- it would be better to run less boost and more timing. You really have to just try it both ways and see which one is making more power for you though. Some engines/setups like more boost while others like more timing. However, if I had to guess, if you're having trouble running more than 9* at 7K then it's probably because the turbo is being run out if it's efficiency range. FWIW, I ran a stock 8 turbo and found that I got better results with about 22psi and 12-14* of timing @7000. However, I know a lot of people are able to run even more timing than I was.
Old Aug 12, 2011 | 07:54 PM
  #1204
GregM's Avatar
Thanks, will take the car out now for a play and let it taper abit more. Check the log and then add some more timing.
Old Aug 12, 2011 | 08:17 PM
  #1205
wizzo 8's Avatar
Just out of curiosity what's your peak tq timing at with only 9 up top?
Old Aug 12, 2011 | 08:20 PM
  #1206
GregM's Avatar
Only about 4.
Dropped the gain down to minimum on my boost controller and now tapers to 23psi.
Old Aug 12, 2011 | 09:45 PM
  #1207
GregM's Avatar
Heres a log and timing map, let me know your thoughts
Old Aug 13, 2011 | 11:49 AM
  #1208
211Ratsbud's Avatar
Serious knock , your load looks high for that turbo.
Old Aug 13, 2011 | 09:42 PM
  #1209
06RedRalli's Avatar
GregM,
the load's that you're hitting are what I hit with my 20g on e85...I'd look for the source of your high loads...IMO you should not be that high...
Check for boost leaks...could be the culprit.
Old Aug 13, 2011 | 09:55 PM
  #1210
GregM's Avatar
Originally Posted by 06RedRalli
GregM,
I just did a boost leak test and I can hear air near the turbo, dammed if I can feel any leaks around there thou. About the only place I can't check is the back of the intercooler..............
Old Aug 13, 2011 | 10:17 PM
  #1211
06RedRalli's Avatar
May be a hose has a slit...bad gasket from your j-pipe...or the coupler on the j-pipe is leaking.
Old Aug 13, 2011 | 10:21 PM
  #1212
GregM's Avatar
It will have to wait till next weekend, but I may pull everything apart and check everything. I've been getting high load like that since I went to the bigger turbo. My car normally has a TD04 on it, not an 05.
Old Aug 13, 2011 | 10:54 PM
  #1213
chetrickerman's Avatar
Veteran: Army
if you dont have any boost leaks you may want to check your MAF scalings. the MAF is what determines the load, and if your scalings are low, it will read a higher load
Old Aug 13, 2011 | 11:03 PM
  #1214
GregM's Avatar
My car is not an Evo, so my load maybe different. My MAF is smaller then an Evo one. I had an Evo one on my car a few weeks ago and the Injector Scaling was different even after copying an Evo's MAF settings, so theres abit more going on there. I'll try and get some info from some other Airtrek owners. If everyone can look past the load and give me some feedback on the rest of my setup I'd appreciate it.
Old Aug 14, 2011 | 03:43 AM
  #1215
3K's Avatar
3K
Try adding 3* across from 200-340 load from 7000-11000rpm and smooth from there.
