Let's see your fully tuned timing maps
My apologies in advance if you weigh 600lbs. But how exactly does one get an evo to weigh 4163 lbs??? I know your mod sig has subs in the list, but are the enclosures made of 1/2" SS wall? Do you have 20 subs in your car? An anvil in the trunk?
Here's the timing map...
Uploaded with ImageShack.us
Am I running too much timing? CALI 91 so I get the occasional 1-2 counts here and there, never more than 2 unless its shift knock.
walbro, dp,tp,catback,licp,intake filter, and mbc @ 21 psi
ALSO my boost hits about 21 psi 2nd and 3rd gear, then 4th gear 22-23 psi, 5th gear is near 24 psi... this is at night btw. do I need to start porting things?
I have NO clue what that is
I guess that's what separates the pros from the amateurs lol...
I tried interpolating like killerpenguin said...
got the above log... strange because I used to make about 310 whp and 280 wtq on VD but I'm making less now.. I think its because I turned the boost down to around 21 psi rather than 23 psi?
I guess that's what separates the pros from the amateurs lol...I tried interpolating like killerpenguin said...
Yes, boost will be higher in each gear, especially with a MBC. The only way to have it the same in each gear, is to do gear based ECU boost.
Also, do you have the definition handy I'd like to add it since I don't seem to have the table
You are on ROM 8859 right?
**update**
FINALLY finished the fuel map too....
Boosted, how do I look?
ive done pulls in anywhere from 50-100 degrees and seen no changes...
Yes a lil bit too much timing from my Knowledge, Also your car seems to be a little bit on the lean side during your Midrange.. since its 91 Oct. You can lean the top out a bit where it goes to 11 flat... aim for 11.5at 3500-6500..11.4-11.3 at 7k and 11.1 at 7500.
As far as the boost issue, look into Ecu controlled boost. I have Gear based boost, it works awesome as i have it set to lower boost in 5th for freeway.
