Let's see your fully tuned timing maps
yup. it really sucks when im sitting at home bored with nothing to do. then im like, now what can i do to my tune??
like i have had this knock problem in the 6600-6900 range where i will get 2 counts of knock 2 out of 3 WOT runs, but it happens no matter if i have 11* there, or 18* there.
so I increased the knock multiplier in that range by 1 and am going to see how that works out
what are the corresponding rpms for low mid and high ?
the rest of the knock multiplier map is stock.
You got to remember that your talking to everyone in here about tuning 8's and 9's. Much different then the timing of a EVO 10. Just something to keep in mind when suggesting things if you haven't got experience with past ones.
Also, raising the knock filter to see if its phantom knock is very incorrect and dangerous.
i would not have done it without the suggestion of knowledgeable pro-tuners
i didnt raise it to see if it was phantom knock, maybe i used the wrong words in that post you quoted. i confirmed it is phantom knock with not only changing the ignition timing up and down, which had no effect on the 2 counts of knock in that area, and also with detcans
P.S. possibly will move from 6 to 8 degree on peak load (4-4.5k rpm) - since it is more knock stable.
Chaning something as simple as my front motor mount induced quite a bit of low end knock. Can you explain how to get rid of this without adjusting the knock filters?
