Let's see your fully tuned timing maps
Old Jan 27, 2013 | 08:55 PM
  #2056
Quilem's Avatar
Disregard
Old Jan 27, 2013 | 10:07 PM
  #2057
Quilem's Avatar
Disregard all I just posted... Just noticed that the base map which I was using that I got from a friends had a bunch of things tampered with related to the MAF... So I'm going to start fresh... Ill let yall know how that goes... I'm glad I posted it up here and you guys agreed it was weird... Triggered me to look further into the map... Now I have to start from scratch! but its okay. This totally explains all the headaches Ive had with the map...
Old Jan 27, 2013 | 11:43 PM
  #2058
stunt2's Avatar
Originally Posted by jedibow
Unless you are running the tephra rom for 94170015 you will be logging the incorrect load variable, 1 byte is only accurate for the above ROM, other than that you need to log 2 byte load temp and baro corrected for your specific ROM.
yes mate, thanks to 10isace I've already sorted that. logged 2 byte load and it pretty much matched the map. but not sure if I've logged baro and temp compensated one. If you can post up mut adresses of that, I'll compare it
thanks in advance
Old Jan 28, 2013 | 09:18 AM
  #2059
10isace's Avatar
thanks in advance
That's what your using.
Did you fix that 12-11-12 timing up top on your timing map?
Old Jan 28, 2013 | 09:57 AM
  #2060
stunt2's Avatar
havent't touched anything yet, car is parked for a while
Old Jan 29, 2013 | 07:04 AM
  #2061
HsamehH's Avatar
Unless you are running the tephra rom for 94170715 you will be logging the incorrect load variable, 1 byte is only accurate for the above ROM, other than that you need to log 2 byte load temp and baro corrected for your specific ROM.
yes i had exactly same problem and didn't find explanation till i saw your post.
i am using 94170015 with 1 byte load and the load i log different than my timing values in the lower load..i knocked until i found it but don't know how to fix it(switch roms?),i had to block tune some areas.
Old Jan 29, 2013 | 08:52 AM
  #2062
10isace's Avatar
Are you saying you fixed it or that you need some help?
Old Jan 29, 2013 | 08:03 PM
  #2063
mrb00st's Avatar
03 gsr
mods
SD
COP
muse o2 dump
BC 272 cams
1200 injectors
stm upper and lower icp
10.5 hotside
3" turboback
peaks @ 26psi 285ish load and falls to 245 load
any tips would be greatly appreciated
Old Jan 29, 2013 | 08:12 PM
  #2064
domyz's Avatar
Originally Posted by mrb00st
03 gsr
mods
SD
COP
muse o2 dump
BC 272 cams
1200 injectors
10.5 hotside
3" turboback
That looks great. Seriously you win the "nothing to say map of the month"
As for advices, do you have any knock?
Which octane ?
  #2065
Raptord's Avatar
03 gsr
mods
SD
COP
muse o2 dump
BC 272 cams
1200 injectors
10.5 hotside
3" turboback
At a quick glance, looks quite good.
Old Jan 29, 2013 | 08:17 PM
  #2066
mrb00st's Avatar
zero knock. car runs amazing. just figured id post to get other thoughts on it. this is my 93 map.
Old Jan 29, 2013 | 08:24 PM
  #2067
domyz's Avatar
My two cents:
This thread has 138 pages. There is like 20 maps that looks good, run good, no knock, and have a good construction. They're mixed into 200 not so good maps with knock, other issues, odd tricks.
I know merlin's/TB guide has some maps but it wouldn't hurt if we had a bigger database with different mods/cars/setup. It would really help new DIY tuners to have a thread with good rated maps (I would have been happy to have that).
Old Jan 29, 2013 | 08:28 PM
  #2068
mrb00st's Avatar
Originally Posted by domyz
My two cents:
i personaly like that idea alot. i know when i started tuning on my evo and other dsm's in town. i looked at this thread alot to learn what people were doing wrong and tried to not make the same errors with mine. I think it would be great for a database of "good" maps with the mods along with them.
Old Jan 29, 2013 | 08:37 PM
  #2069
domyz's Avatar
Yes this thread is very good to see what not to do (I'm serious). This is helpful.
Old Jan 29, 2013 | 08:41 PM
  #2070
mrb00st's Avatar
lol yes. i have deff seen some maps that made me say "whhoooaa wtf"
