Let's see your fully tuned timing maps
your peak load should be your lowest timing point.
find a spool timing amount that doesnt knock. tune your full load cells. go back to your spool timing and add a degree. Heres how I set my scaling up.
RPM increase 250 increments no matter where. start at 1000 and should make it to 7500 or so.
I literally interpolated my timing after setting my RPM to that and the timing curve is nearly identical for me. I tune a lot from the 3d view, and with your RPM and load scalings consistent you can gain a better feel of trending.
Vertically. You can hold timing for 500 rpm after peak load so you'll have 1* for 750rpm then interpolate after that. So you'll have to highlight your last row of 1* to your top end . Then for safety's sake I highlight the loads after my target and decrease the whole column by 1* every 20 load.
Again consistent axis scaling is crucial for best visualization
Guarantee for success ? No but it's the concept
When you're starting out tuning each cell sucks so I make bulk adjustments.
Any helpful opinions on an Evo IX, FP Red, e85 tune... ?
Its an 06 Evo IX with completely stock unopened motor. Mods include Megan O2, Megan Downpipe, 3" intercooler, and FP Red 84mm turbo with a custom Mivec map. My first time playing with e85, I'm hitting 310 load and i have zero knock other then random shift knock. The car has always liked a little bit of timing and is tuned to the curve and not pulled back from knock. I still want to play with it a little more and check a few things but some opinions would be nice before i put the final touches on it.
Quick question... what causes the dips in power at 5500 and 6500 rpms?
Take a look at your timing from 240 on up in the upper rpms. You have a bunch of 8-7-8 as rpm increases and so on.
The dip in your graph is the is your actual power. That big spike at the end is from the road you're using. Do smoothing 3 and clip the rpms at 6750 and that will give you a more accurate representation. Might wqnt to read the virtual dyno tips thread in the dyno results section.
Update your version on Virtual Dyno and don't hide your power numbers.
I am also adding a scaling that would help with resolution on your map.
I guess my question is for timing really hard to understand
does increase or decrease timing makes a faster spool up until you reach peak?
Then From peak to ending peak on the load vs rpm scale do you keep increasing timing down the blocks until you hit knock to hold that boost for power?
It seems like this is my main struggle, fuel tuning is easy as ramen noodles
I guess help me understand im at 26 pounds of boost but my timing is indeed pretty low
The other theory suggest to decrease advance and richen AFR to create heat for spool, but you'll lose some torque while doing that.
It's as simple as:
- Timing decreases when load increase and
- Timing increases when RPM increase.
If you're building the map with these rules in mind, you automatically have these effects:
- When you're spooling up: Timing will decrease until peak load
- At peak load: RPM will rise faster than load decreases so timing will continue to increase
Example you have this ramp from peak load (ignoring AFR and boost influence)
5-5-6-6-7-7-8-8-9-9-10-10-11-11
If knock occurs often when timing raise from 7 to 8 try:
5-5-6-6-7-7-7-8-9-9-10-10-11-11
If it occurs again try
5-5-6-6-7-7-7-7-8-9-10-10-11-11
You see you have to keep the curve increasing, don't create a decreasing dip like in the map you posted.
Everytime you have rework the map to keep following the above rules...
..............and for reference these two maps posted recently will show you what I explained: Obviously my current map /211ratsbud map
It's as simple as:
If knocks occur often when timing raise from 7 to 8 try:
If it occur again try
- timing increase when RPM increase.
Good explanation.
