Let's see your fully tuned timing maps
Old Jun 4, 2020 | 06:46 PM
  #2866
211Ratsbud's Avatar
Hey guys, looking for a pointer or two...
2.4 LR 9:1 CR
S2 Cams
GTx3582 gen 2
Skunk 2 intake manifold ( ported at stm)
Do these base timing figures for wide open throttle seem safe for 93 octane? Im working on det can set up, AFR low 11's. I have done quite a bit of research and I believe they are conservative but wanted to gain some input from some with more experience here.
thx
Old Jun 4, 2020 | 07:02 PM
  #2867
Abacus's Avatar
More timing is needed.
These cars tolerate 0-3 around 3500,5-6@5500 then make it up to 11-14 by 8000 on most fuel. A big turbo car may take more on the bottom end of things with less cylinder pressure but don't get carried away.
These cars take moderate boost with low timing. 23+psi on that turbo with 12-14 out the top should be in the ballpark to start.
A dyno session is money well spent IMO. Safe environment to measure exactly whats going on.
Old Jun 4, 2020 | 07:32 PM
  #2868
211Ratsbud's Avatar
thanks for the tips. currently I hit the wastegate at just a whisker over 4k (14psi). The car is running a 1.01 twin scroll gtx3582 gen 2, boost comes on pretty fast and am expecting 23-24 psi easily by 4250ish. Ive done some fuel mapping on the bottom end, and wanted to start ball parking the rest of the map with out being close to the edge of timing. I made some improvements to the timing since i read your suggestion, I will post it in a follow up. This has been a 5 year build getting the stuff together lol.
Old Jun 4, 2020 | 07:39 PM
  #2869
211Ratsbud's Avatar
heres my updated following some advice. Keeping peak load/peak boost low for the time being until I start increasing the boost to actually find out where it hits. Sort of a mystery just yet...
Old Jul 27, 2020 | 12:31 AM
  #2870
Borge Fagerli's Avatar
Here are mine. 2006 EDM Outlander Turbo. Previous owner told me it wasn't tuned, but there's a blow off valve and many of the tables in the ECU have been modified so he either lied or just didn't know what he was talking about - he seemed pretty clueless about things (he didn't even know the AC compressor was removed from the car when he owned it) so the latter is most likely.
Everything else is stock, as far as I know - this is basically a detuned version of the EVO 8 engine, but I will be installing a 3" turbo back system soon.
Running on 98 octane most of the time, but gas prices fluctuate wildly (Norway) so I sometimes go for the 95.
Old Jul 27, 2020 | 11:13 AM
  #2871
Project_Broke's Avatar
Maps could see improvement for sure.
Choppy and large jumps of timing aren't great.
Power left on the table as well. I would start by smoothing them out and see where it puts you.
Old Jul 28, 2020 | 02:52 AM
  #2872
Thanks. Here are the smoothed maps.
Are there any areas you think I should add or subtract timing?
Old Jul 29, 2020 | 09:28 PM
  #2873
No one with an opinion?
Old Jul 30, 2020 | 04:47 AM
  #2874
What kind of load values are you hitting?
Around 0-2 at 3000, 12-15 at 7500 is a good place to start.
Old Jul 30, 2020 | 09:04 AM
  #2875
Thanks. Should be reaching 200, having some tech issues with logging so had to order a 1.3 cable to see if that fixes it.
Old Jul 30, 2020 | 09:28 AM
  #2876
Your high Oct map is set pretty close to where I would start at around 200.
Still has some large jumps.
Have you tried using the Map smoothing worksheet?
Old Jul 30, 2020 | 09:42 AM
  #2877
Yes, this was after one iteration of the smoothing worksheet. Maybe run it one more time?
Old Aug 1, 2020 | 05:41 AM
  #2878
Yes, also rescale the y axis so you can have better resolution.
You don't need 11k+ obviously.
Old Oct 9, 2020 | 12:23 PM
  #2879
NP's Avatar
NP
5 Year Member
Got tuned on a dyno. Need opinion on E85 timing map.
built block
about 30 psi
stock frame gtx3576
E85 fuel
Old Oct 9, 2020 | 03:16 PM
  #2880
Lumpy Sticks's Avatar
5 Year Member
^^^^ Too much timing in boost!
