Let's see your fully tuned timing maps
Old May 15, 2011 | 09:19 PM
  #901
killerpenguin21's Avatar
id say its a combo of the stock ic and 26psi. why spike so high? on stock cams im using 4* at peak with not an ounce of knock on 24ish psi, and may go up to 5* eventually.
Old May 15, 2011 | 09:56 PM
  #902
211Ratsbud's Avatar
I honestly dont normally run it that high, usually 22-23 psi. I kinda got antsy and turned it up and decided to tune for a higher boost, so my map was more completely tuned. Ill probably turn it back down, especially since I autocross. Id really like to upgrade my intercooler and see what kinds of gains can be made. I def know cams run less timing. For a while i was running a lot more timing in these areas. however I started tuning in the dead of winter so, as I find a hotter day, i find that I cant make the same power and run the same timing. lol
Old May 18, 2011 | 09:30 PM
  #903
is anyone using the map smoothing excel spreadsheets?
ill post mine up in the morning, it seems to have done a very good job.
Old May 18, 2011 | 11:25 PM
  #904
Fast_Freddie's Avatar
Veteran: Navy
I smooth maps manually... takes a bit of time though...
Old May 19, 2011 | 09:10 AM
  #905
this was a long attempt at smoothing/upping spool timing by me. you can see its not that good still, there were areas i couldnt figure out how to smooth without changing areas i didnt want to change.
then i stuck it in the spreadsheet.
much better.
Old May 19, 2011 | 11:59 AM
  #906
10isace's Avatar
Where do I get this smoothing spreadsheet?
much better.
Old May 19, 2011 | 12:20 PM
  #907
evo8426's Avatar
Here ya go
http://professionalawesome.com/EVOMa...ngv24_xlsm.zip
Old May 19, 2011 | 12:36 PM
  #908
10isace's Avatar
Thanks!
Originally Posted by evo8426
Old May 19, 2011 | 12:58 PM
  #909
Is that the big maps one or the evo 9?
The big maps one I couldn't get a good download of
Old May 19, 2011 | 01:09 PM
  #910
evo8426's Avatar
big maps
Old May 19, 2011 | 02:42 PM
  #911
4g94T's Avatar
That smoothing spreadsheet works great!
Is there one for the fuel map also?
Old May 19, 2011 | 02:56 PM
  #912
evo8426's Avatar
its all in the one file, check the tabs at the bottom of the workbook
Old May 19, 2011 | 03:00 PM
  #913
4g94T's Avatar
right... thanks!
Old May 19, 2011 | 03:35 PM
  #914
Raptord's Avatar
The excel files are a good start to getting your maps smoothed out, but for optimal results you need to spend some time doing it manually afterwards
Here's how my graph looks, I won't post my map since it's originally based on a tune by tscompusa (unless you dont mind Tom)
Old May 19, 2011 | 05:25 PM
  #915
Yeah for me I helped because I have an easier time having it start smooth and then just keep my changes smooth, smoothing a chunky map was becoming way too overwhelming an I was winding up with values I didn't want to be using in important areas.
I also likethat the sheet shows you the change between two maps so I could track how many degrees I was adding.
