Let's see your fully tuned timing maps
Old Jun 22, 2011 | 05:38 PM
  #1036
nightwalker's Avatar
Who runs 12.0 afrs up top on pump? Are these glory pulls?
Please don't attempt running experimentally lean AFR's if you are reading this and are just starting to learn how to tune your own car.
Old Jun 24, 2011 | 10:47 AM
  #1037
TJung's Avatar
Hello. Can somebody say something about my map?
Old Jun 24, 2011 | 10:54 AM
  #1038
06MREvo's Avatar
What kind of fuel do you run? It's definitely a bit messy...Could use a good bit of smoothing...It shouldn't be aggressive like that then drop 3-4 degrees in the last column...
Old Jun 24, 2011 | 10:56 AM
  #1039
TJung's Avatar
I am running euro 99 oct Shell V power Racing only. Mods in my sig, boost 24 psi -> 23 psi@redline
Old Jun 24, 2011 | 11:09 AM
  #1040
06MREvo's Avatar
I am running euro 99 oct Shell V power only. Mods in my sig, boost 24 psi -> 23 psi@redline
99 oct...Your lucky to have that over there...Do you have any logs from Evoscan you can post?
ps, you should sell me your car...thanks...
Old Jun 24, 2011 | 11:20 AM
  #1041
RazorLab's Avatar
It's 99 RON, so basically same as our 93 oct.
USA (AKI/PON) = Europe (RON)
Regular........... 87 = 91
Plus................ 89 = 93
Premium......... 91 = 95
Premium Plus... 93 = 98
Old Jun 24, 2011 | 12:01 PM
  #1042
TJung's Avatar
Currently I don't have on this laptop. I will post some maybe tomorrow. And I am not sure if razorlab is right. Shell says that this fuel have 100 oct actually. And it's not the same as regular euro 98
Old Jun 24, 2011 | 12:07 PM
  #1043
06MREvo's Avatar
Interesting...
Old Jun 24, 2011 | 12:12 PM
  #1044
Boosted Tuning's Avatar
razorlab is right. There are multiple methods of measuring octane.
In America, its called "AKI" or "anti knock index", which to calculate, takes the sum of the RON and MON of that gas, and divides them by 2, to get AKI. (R+M)/2
Most all other countries rate the octane of their gas by using only the RON number.
Therefore a gas with a RON of 98, has an AKI of about 93-94.
Old Jun 24, 2011 | 12:16 PM
  #1045
fugiwara's Avatar
No wonder is Asia I see 92, 95, 98 @ gas station.
Old Jun 24, 2011 | 12:24 PM
  #1046
02rexwi's Avatar
Hey guys, I'm new to tuning Evo's, I come from the Subaru world of ECU flash
A friend has asked me to help him tune his Evo, and after taking a ride with him and seeing his UEGO show 12.3-12.7 through a pull at 27 psi. I am a bit hesitant to even touch the car because I dont know how it hasn't blown up yet...
Anyways, when you guys are referring running 12 degrees at redline, is that total timing, or is that just advance?
In the subaru world its normal to use 19 degrees total timing at peak torque to hit MBT (on E85) and up to 29 by redline.
What kind of total timing do you guys typically see on 93 octane and E85???
Sorry to threadjack, I just figured a timing thread was a good place to post.
Old Jun 24, 2011 | 12:28 PM
  #1047
RazorLab's Avatar
Total timing the car is actually running. The Evo/RA's do not have dynamic advance like the Subaru's do. The Evo/RA 4G63 and 4B11 take MUCH less timing then the EJ20/25's.
If you tune it like a subaru, you will blow it up.
Old Jun 24, 2011 | 12:32 PM
  #1048
Raptord's Avatar
When we say X degrees at redline, that's what the car is logging in evoscan. It's also what should be in the timing map at the relevant RPM/load, supposing there isn't any knock to bring down the timing.
For your friend's car, start by making the map richer by ~1 AFR above 200 load and go from there. To keep things smooth I would recommend richening by .1 from 200 and up, then another .1 from 190 and up and so on until you reach 100 load. If you have 20-load increments between 100 and 200 load then increment by .2 instead of .1. This will avoid sudden changes in the fuel map and get the fueling to a more reasonable level.
Old Jun 24, 2011 | 12:45 PM
  #1049
02rexwi's Avatar
Ok, thats kind of what I figured after reading through a bunch of posts. Thanks for the quick reply!
Since we're on the subject of tuning differences I have a couple more questions:
1. What units are used in the timing table? Does 200 mean 200% volumetric efficiency?
2. When using the ECU to control boost, can you control the maximum wastegate duty cycles like a Subaru so that I can use a 3 port solenoid and MBC together to tune boost?
Old Jun 24, 2011 | 12:52 PM
  #1050
RazorLab's Avatar
I suggest taking a look at merlin's guides here: https://www.evolutionm.net/forums/ec...ing-guide.html
Timing table is RPM x Load
