Let's see your fully tuned timing maps
Old Aug 14, 2011 | 11:21 AM
  #1216
chetrickerman's Avatar
Veteran: Army
Originally Posted by GregM
My car is not an Evo, so my load maybe different. My MAF is smaller then an Evo one. I had an Evo one on my car a few weeks ago and the Injector Scaling was different even after copying an Evo's MAF settings, so theres abit more going on there. I'll try and get some info from some other Airtrek owners. If everyone can look past the load and give me some feedback on the rest of my setup I'd appreciate it.
load is load. load is determined by how much air is being pulled through the MAF. its not just about your MAF size, its about your intake tubing size. you have to scale the MAF to that size tubing.
something just doesnt seem right here, either your MAF scaling is off, or your load scaling is off
did you self tune your car?
Originally Posted by 3K
Try adding 3* across from 200-340 load from 7000-11000rpm and smooth from there.
why? he is having 5 counts of knock at 7k rpms. 7-8* timing at 23 lbs of boost seems pretty good and if i were him i would try to lower the timing there to 6* to see if it gets rid of the knock
Old Aug 14, 2011 | 12:22 PM
  #1217
GregM's Avatar
Its running the factory intake pipe and MAF settings. Yea, I'm trying to tune it myself, but even thou it drives fine, I'm sort of getting over it.
Old Aug 14, 2011 | 05:12 PM
  #1218
Veteran: Army
then i would say you have a boost leak if your doin 300+ load and only pushing 25-26 lbs of boost
Old Aug 14, 2011 | 05:29 PM
  #1219
b16a2delsol's Avatar
I get 306 at 25 psi..... I don't think there is any boost leaks lol .
Old Aug 14, 2011 | 05:37 PM
  #1220
GregM's Avatar
I've been told of a 2.3 Airtrek, same turbo and not tuned properly getting just over 320 load, not sure what boost, but wouldn't expect alot due to the tune.
306 load at 25psi, but you have an FP Green and cams.
In any case, I'll be looking at pulling all the pipe work apart and inspecting the intercooler. I'm assuming any leak I would have would have to be pretty small or else the turbo would not get up to 26psi in the first place, which also has me wondering if there is a leak or not.
Old Aug 14, 2011 | 06:39 PM
  #1221
3K's Avatar
3K
Originally posted by chetrickerman why? he is having 5 counts of knock at 7k rpms. 7-8* timing at 23 lbs of boost seems pretty good and if i were him i would try to lower the timing there to 6* to see if it gets rid of the knock
IMO, he's probably knocking from too little timing at that RPM range. He should be around 11-13* at that rpm and load. Just my opinion though.
Old Aug 14, 2011 | 07:15 PM
  #1222
Veteran: Army
This >
your turbo flows more air at the same pressure
that could be true.
Old Aug 14, 2011 | 07:31 PM
  #1223
GregM's Avatar
Thanks guys, I will try increased timing before I pull everything apart. I've dropped a degree or 2 out of the timing and it didn't make any difference, so it may be too low as suggested.
Old Aug 14, 2011 | 07:48 PM
  #1224
Veteran: Army
yea, i would progress it up to 10* and see how that goes
Old Aug 15, 2011 | 01:31 AM
  #1225
GregM's Avatar
Well, the car felt far better by increasing the timing, I couldn't believe the difference. I increased my max timing by 3 degrees and filtered that down to 1. On the Virtual dyno my power output jumped from about 180kw to 220kw. I still had knock at the higher rpm thou, so I may just need to increase the timing even more. In one run thou I had 6 counts of knock from 5500rpm, timing was at 8 degrees that pull. The next pull it was clean through to 6000rpm with timing of 10 degrees and knock counts of between 2-4 ran through to 7000rpm with timing maxing at 12 degrees.
Old Aug 15, 2011 | 04:38 AM
  #1226
wizzo 8's Avatar
Maybe its because its not an evo but it looks like you are running too rich.
Old Aug 15, 2011 | 07:47 AM
  #1227
I'm guessing he is at sea level where I am 4500 ASL @ 12.7 AP. So its less evident having a slightly bigger turbo.
Greg are you setting your low Oct fuel maps the same as your high ? And have you tried cleaning your maf ? I have heard of people getting knock because of dirty mafs...
Edit: spark plug heat rang ?
Old Aug 15, 2011 | 08:57 AM
  #1228
Veteran: Army
yea, lean that out to 11.6-11.2 range.
But you don't want to only do 1 pull the see your results, to 3 consecutive pulls then look at your logs so you can see if your AFR's are consistent, if you have any constant/consistent knock and all other variables of your tune
Old Aug 15, 2011 | 09:01 AM
  #1229
killerpenguin21's Avatar
yes, do multiple pulls. almost always i will my knock counts will drop over the 2nd/3rd pull.
Old Aug 15, 2011 | 10:47 AM
  #1230
GregM's Avatar
Double post
