Strange issue with trying to read '06 Evo 9 MR ecu
Old Mar 28, 2008 | 10:13 PM
Slo_crx1's Avatar
The issue is that I can't! For some reason I can't get EcuFlash to connect to my friend's car to start tuning it for her. Every time I try to read the ecu I get a message like this:
[12:05:08.489] sending init sequence 1 (0001)
[12:05:11.753] sending init sequence 1 (0003)
[12:05:15.028] sending init sequence 1 (FFFF)
[12:05:17.792] no response to any known code
I have the newest drivers for the Tactrix cable and a pretty recent update of EcuFlash, but I still can't get anything off of it. I know the program and cable works because I just did a reflash on my car before trying to read the MR. Anyone have any insight to this?
Old Mar 28, 2008 | 11:11 PM
recompile's Avatar
If it's already been flashed, it may have been locked by the previous tuner. You will need the Unlocker from AktiveMatrix.com
Old Mar 29, 2008 | 07:12 AM
Slo_crx1's Avatar
That's what I thought might have happened too, but when I asked the girl she said it's never been flashed and she's owned it from day one when the car hit the dealership.
Old Mar 30, 2008 | 08:45 AM
Pd1's Avatar
Pd1
Low battery voltage will cause this error. Put a battery charger on the vehicle when you're trying to read the ROM and see if you still get the error. I had the same thing happen to me on a car I tuned last week with a mini battery.
If it's something else, it won't hurt to run the unlocker and see that allows you to download the ROM. From what you've said, my money's on battery voltage.
Old Mar 30, 2008 | 03:23 PM
tephra's Avatar
where did you get the cable?
this is the 3rd case now of not being able to read that I have seen...
Old Mar 30, 2008 | 06:51 PM
codgi's Avatar
Edit. Now re-read the OP's post properly. Cable works on another car so its probably something wrong with the ECU.
Old Mar 31, 2008 | 12:06 PM
hellcat's Avatar
I had an issue reading a car not long ago. I tried everything and nothing worked. It turned out to be the wire in the plug next to the obd2 plug. The wire above it had been cut. Took me 2 weeks to figure it out. I felt like a tard for not checking it sooner.
Old Mar 31, 2008 | 12:09 PM
KevinD's Avatar
turn off headlights, radio, anything electric and repeat. low voltage will cause it to cont connect, or loose connection midway. if you can't read it at all, get the unlocker.
Old Mar 31, 2008 | 03:39 PM
Slo_crx1's Avatar
I'll try these ideas out when I get a chance. I usually turn all electrical loads off when trying to read or flash (lights, radio, etc.) but this Evo didn't even seem to be communicating with my cable...it was like I plugged it into a blank obd2 port. It's very possible that the dealership might have cut the one wire that enables flashing, I'll check that out too and if that's not the case I'll try the unlocker as well.
Old Apr 2, 2008 | 08:51 AM
apagan01's Avatar
bump
Old Apr 18, 2008 | 11:06 PM
Mr Evolution's Avatar
I'm having a similar problem. I was able to read the rom a few days ago and now it doesn't do anything.
I changed the map sensor and also changed the tables according to mrfred's thread instruction on the 3bar map sensor.
Might have to change everything back and see if it fixes the prob.
Old Apr 18, 2008 | 11:07 PM
Really discouraging
Old Apr 19, 2008 | 06:58 AM
gudmundur's Avatar
My friend has a IX 2006 which I was unable to get a connection to with EcuFlash.
I finally found out that if the car is running I am able to read and write to the Ecu, as soon as Ecuflash starts preparing to read or write the engine dies.
This is the only way I found that worked.
We put a new battery in, checked the voltage and so on but all that was ok.
I also checked the wires and as far as I could see those were ok aswell.
Gudmundur
Old Apr 19, 2008 | 02:48 PM
I have never been to the dealer and only serviced the car myself. I also was able to read before.
Old Apr 21, 2008 | 12:39 PM
bnice01's Avatar
try reinstalling ecuflash, i had this happen to me once
NigHtcRawl3R
Jan 20, 2013 11:14 AM
jaekaelae
Dec 1, 2012 06:01 PM
Hollywood_Evo
Nov 8, 2011 06:22 AM
rgar
Jun 18, 2010 05:14 PM
DoughtCom
May 8, 2008 09:04 AM
