how-to: Log AFR from the LC-1 w/o a serial cable
alright guys im having trouble with the ecuflash part. what is mut address
<table name="Rear O2 (ADC 0A) RAM variable" category="Rear_02" address="?????" type="1D" level="1" scaling="Hex16"/>
PLEAE help
. i have the pin installed and tephra's o2 simulator on. i tired to log it but its at a steady 13.xxAFR through the ecu.
PLEAE help
ok i plan on doing this real soon to my buddies Evo 8 with an AEM Uego WB and to my evo 9 with a LC-1 WB. is this worth doing? i would like to think so since hooking up all those cables can be a pain in the a$$ sometimes. it seems better to log with just one cable. also i bought my cable along with the evoscan program. after purchasing i read somewhere that the Tactrix cable and the one you buy with the evoscan program are different. will this affect anything if it's true?
also are the pin layouts found on the first page accurate? this looks like it will take some time to do just want to make sure i have everything needed and that i'm prepared for it!
The pin locations are accurate.
Many people choose to completely remove the rear O2 sensor. It easily unplugs from the vehicle harness. Mine is still installed. I have a separate bung for my WB.
this is a neat feature, but I suggest you check your results with a known good wideband sensor-ing normally to verify that you have installed all the procedures correctly.
I know with my install I got readings that looked good but did not match the real afr, but I am sure I didn't do the setup correctly.
i thought it had to be removed due to the fact that it wasnt being used and it wasnt "on". the heat from the exhaust would damage the sensor if the heater of the sensor wasnt working. so is the sensor still working just not sending the info to the ecu? if so that would be nice. wouldnt have to worry about removeing the sensor at all.
