how-to: Log AFR from the LC-1 w/o a serial cable
Old Jul 10, 2009 | 05:50 PM
  #211
draconx's Avatar
Originally Posted by draconx
alright i changed the MUT to the above and now i have check engine light. i did tephras o2 sim. but its still on. any ideas??..
anyone??...
Old Jul 10, 2009 | 06:22 PM
  #212
vmrevo9's Avatar
Veteran: Air Force
bump ^^^^^
Old Jul 10, 2009 | 09:09 PM
  #213
mrfred's Avatar
Hard to tell what you did. Are you using a tephra v5 ROM?
Old Jul 10, 2009 | 09:13 PM
  #214
draconx's Avatar
yea i am. i pulled the o2 sensor pin out of the ecu and then added the lc1 wire. then added a 1 to tephras ' o2 simulator' and then added that address into the mut table.
Old Jul 10, 2009 | 11:30 PM
  #215
mrfred's Avatar
What was the original value for MUT12? What CEL are you getting?
Old Jul 11, 2009 | 12:44 AM
  #216
draconx's Avatar
Originally Posted by gsrboi80
ok 0x8409 to the mut table Row 1 (Y) Column 2 (X) Where 88B5 is currently
mrfred: it had 88B5 in ther. i changed it to 0x8409. and the check engine light is for ' heater sensor somethin'. (i have not pulled the code for a week now so i dont really remember).
Old Jul 11, 2009 | 05:53 AM
  #217
mrfred's Avatar
It sounds like you did everything correctly, but something a mistake must have been made somewhere. Did you upload the ROM to the ECU after you enabled the O2 simulator and changed MUT12?
Old Jul 11, 2009 | 12:17 PM
  #218
l2r99gst's Avatar
Does anyone have this working on V5 96530006?
I finally got around to wiring in my LC-1 wideband to my ECU today, pin 75, analog out 2, brown wire. The ground wire is grounded.
When I log 0x8409, I get 0. My next step is to use my multimeter to verify whether the analog out is working or not, but I just wanted to make sure there wasn't anything else wrong, like the rear O2 sim in the tephra rom or something like that.
I don't think 96530006 has a rear o2 from the factory, so should there be a certain periphery that we need to turn on, or that doesn't matter in terms of logging the input?
EDIT: Just checked with my multimeter and the analog output #2 is working fine. I just turned my ignition to acc and waited for the LC-1 to warm-up and it the XD-16 gauge read 15.9 and the multimeter read 2.83V. So, for the LC-1 default settings, that's just about right:
.05859x+7.4 (using a .05 offset that mrfred mentioned):
2.83V/5V=.566
.566*255=144.33
.05859*144.33+7.4=15.86
So, the output is working and is accurate. But, when I log it, it just sits at 0. I was logging via DMA, but I know that's set up correctly. So, I'm just curious if anyone else with v5 96530006 has this working.
Thanks,
Eric
Old Jul 11, 2009 | 01:54 PM
  #219
logic's Avatar
I've been using this on both v5.10 and v7t6 with an LC-1 just fine without any odd periphery changes; both DMA and MUT logging are working as expected. I just confirmed to be sure, and I've attached the brown output of the LC-1 to the ECU, and logging address 0xffff8409.
A problem with the ECU harness or wiring, perhaps?
Old Jul 11, 2009 | 02:00 PM
  #220
l2r99gst's Avatar
OK, thanks. As long as I know it should be working. I'll recheck the analog ground, etc, later. Maybe I pulled the ground off when I was rearranging my wires. I'll be sure it's not something I didn't configure right in DMA and just try EvoScan as a second test.
Old Jul 11, 2009 | 02:08 PM
  #221
mrfred's Avatar
2.83V/5V=.566
.566*255=144.33
Thanks,
Eric
My suggestion would be to verify that you can read pin 75 voltage by removing the LC-1 analog output and just shoving a bare wire into the hole in the ECU plug (making sure it reaches the ECU pin). Put a 1.5 V battery across it to ground and watch MUT12 on EvoScan.
Old Jul 11, 2009 | 05:30 PM
  #222
draconx's Avatar
yea. i hooked up the lc1 to the ecu then enabled the 02 simulator. then found the address for the MUT table. still check engine lihgt though .ill double check everything here in a bit.
Old Jul 11, 2009 | 07:20 PM
  #223
mrfred's Avatar
Originally Posted by fixem2
Mrfred, any thoughts for adding the front O2 sensro logic that works with this mod to the V7 96530006?
If I can find time, I'll do it, but its a while down the road.
Old Jul 11, 2009 | 08:17 PM
  #224
l2r99gst's Avatar
OK, it logs fine via MUT. So, it looks like maybe I just messed something up in my DMA setup, since I was testing only with DMA before. I could have sworn everything was setup fine, but obviously I must have missed something.
So, I'm all good. Thanks for the replies.
Old Jul 25, 2009 | 11:00 PM
  #225
vmrevo9's Avatar
Veteran: Air Force
hey guys quick question. i downloaded tephra's v5.10 for my IX and my buddies VIII and i was wondering if that is all i need to do for the patch for running the WBo2's. so all i would have to do is transfer all the modified tables over to the tephra maps? then after installing the analog wire to the ecu and modifing evoscan i should be able to see AFR under rear o2 sensor? also what all does the v5.10 offer? thanks in advance!
