Patch how-to: manifold air temperature logging
Old Jan 18, 2009 | 05:25 PM
  #271
tephra's Avatar
hrmm interesting how your IAT goes UP during spool.
POD filter yeh?..
I think you might benefit from boxing it and running a CAI...
Old Jan 19, 2009 | 06:41 AM
  #272
scheides's Avatar
EvoM Moderator
Except for the fact that I live in MN. There is so much crap on the roads, I would never run a CAI here. Right now its salt/snow/ice/crud which melts and gets into everything. Soon it will be water, ice, and standing water on the roads, and soon thereafter massive puddles. Then just when that's gone, there will be salt/gravel/sand all over the roads, until they finally clean them off at the end of spring.
Tephra, you live down under, if you put a CAI in your car it'd surely suck in some uber poisonous snake or spider and maybe a kangaroo or two?!?!?!
Old Jan 19, 2009 | 01:55 PM
  #273
tephra's Avatar
yeah I guess...
i actually found a baby koala stuck in my exhaust the other day...
Old Jan 20, 2009 | 07:25 PM
  #274
mrfred's Avatar
Originally Posted by scheides
Wow, finally we're through the cold-snap here. It was -20F or COLDER all last week, highs around -2F....TO COLD to even think about doing anything, the garage never warms up, even with a heater! It was a balmy 25F here today, so I *finally* got this done! mrfred, it works perfect! I made sure to copy all of the stuff over as instructed and went for a spin, everything seemed to work as expected.
Log results from a good 3rd gear pull:
Mrfred, beer money! Send me your paypal address!
Glad its working for you. Did you use the latest scaling that I posted a week or so ago?
I'll PM you with my email in a little bit. :-)
Old Jan 20, 2009 | 08:01 PM
  #275
scheides's Avatar
EvoM Moderator
Yes I made sure to use that and beer money is in your inbox
Old Feb 5, 2009 | 12:56 PM
  #276
SkyNight's Avatar
Unhappy
I have some questions.
In Italy and in other European countries the 88580014 are installed on EVO IX RS ECU. Hardware MAT, MAP sensor, SAS, dual BCS are fitted.
MAP and SAS are ok and the function is perfect but MAT doesn’t work.
I searched on the ECU but there is no MAT routine, on the contrary MAP sensor has his routine but is not linearizzed like JDM ECU!
I don’t understand why I have all the hardware but MAT doesn’t work and I don’t understand how the MAP sensor function without JDM setting!
Is there anyone who can answer me?
Old Feb 5, 2009 | 02:47 PM
  #277
tephra's Avatar
i think u will find that 88580014 is the WRONG ROMID for that car.
88580014 has no provision for MAP/MAT/DUAL BCS and not even sure about SAS.
MAP works because its a simple electrical connection and then logging just works. MAT requires some non-linear scaling, which just isn't included in that ROMID. V6 of my mods will include it...
Old Feb 8, 2009 | 02:27 AM
  #278
SkyNight's Avatar
Yes Dave I agree. But…but your MOD it’s an important MOD that permits a lot more functions!
A question for ver. 6.
Normally in the JDM ECU there is a more accurate fuel control with the MDP and MAT.
Do you also put this JDM routine in your new MOD?
Thanks a lot for your work, Giammarco
Old Feb 8, 2009 | 01:41 PM
  #279
ChEvo8's Avatar
thansk
Old Feb 24, 2009 | 10:22 AM
  #280
mrfred's Avatar
Instructions in the second post of this thread have been updated to include the 94170015 ROM. 96530006 instructions have been moved to the second post of this thread as well.
Old Feb 26, 2009 | 09:12 PM
  #281
fixem2's Avatar
MrFred, do you have patched versions of Tephra ROMs or can I just apply the xml changes in EcuFlash and modify the values accordingly?
Where is the ideal location, Intake Manifold or UICP? When I asked Buschur about putting a bung in the IM they recommended the UICP.
Old Feb 26, 2009 | 09:28 PM
  #282
mrfred's Avatar
It will be far easier to just copy the MAT tables over to your existing ROM
If you're planning to do SD, then putting the sensor in the IM makes the most sense from a theory standpoint. Its more work to get it in there though.
Old Feb 26, 2009 | 10:28 PM
  #283
tephra's Avatar
V6 has MAT built in.
We just need to reconcile that against John's SD code
Old Feb 27, 2009 | 04:55 AM
  #284
SkyNight's Avatar
Ok, we wait the V6 with SD
Old Feb 27, 2009 | 07:00 AM
  #285
fixem2's Avatar
waiting.....
