Emissions Help
Old May 20, 2008 | 01:53 AM
evoarri's Avatar
Emissions Help
I have an evo 8. 264/272 cams hks downpipe and cant pass emissions. is there any softwares that can change ready status so i can pass or any ideas on where to start. is says 02s and catlyst arent ready. had a shop check and both sensors are working perfect and cat is fine. im out of ideas.
ANYTHING HELPS
Old May 20, 2008 | 03:07 AM
tephra's Avatar
CEL for cat converter efficiency huh?
what ROMID?
Old May 20, 2008 | 06:25 AM
turboracer's Avatar
Has your car been flashed?
If so did the tuner disable the rear o2?
Look here this might help:
https://www.evolutionm.net/forums/sh...sensor+disable
It describes how to disable the rear o2 check routine.
I would check your rom and see if it has been disabled.
Old May 20, 2008 | 06:43 AM
tephra's Avatar
still might not pass emissions with a non-readiness status..
his best bet would be to try out V5...
Old May 20, 2008 | 09:02 AM
cpoevo's Avatar
We need a list of full mods. I can pass smog in CA on my mods.
Old May 20, 2008 | 09:05 AM
tweakdsm's Avatar
not enough info....
Old May 20, 2008 | 02:49 PM
turboracer's Avatar
What I meant with that info Tephra, was to have him re-enable the routine if someone had disabled it with a flash.
On the OBD II readiness test, the cat and rear o2 tests are usually among the last to complete. How much have you driven the car since you cleared any codes?
DeliriouS
Jul 1, 2025 08:25 PM
boosted8evo
Sep 22, 2012 04:17 PM
500hpOnPumpEvo
23
Jun 29, 2008 09:22 PM
sdhes
Northeast Region
12
May 25, 2006 04:16 PM
4GEvo63
Dec 19, 2005 12:06 PM
