TephraMOD V5.8 - testing help required
Old Jun 4, 2008 | 04:03 AM
taavisev's Avatar
Originally Posted by al\lupo
I can test 88840017 for EDM folks, even if I'm still waiting the harness for altmap. But IMHO there are more common IDs...
+1 and i have harness in place!
thanx
Old Jun 4, 2008 | 07:15 AM
scheides's Avatar
EvoM Moderator
Tephra, is MAP Averaging going to be an option applied to the MAP output, or will it yield a different variable (i.e. need to change stuff in direct-boost mod)?
Old Jun 4, 2008 | 07:21 AM
awddyno's Avatar
willing to test 94170014
Old Jun 4, 2008 | 07:57 AM
cossie1's Avatar
another 1 here that can test 90550001 and I have mine setup to test adc0f
Old Jun 4, 2008 | 08:50 AM
fostytou's Avatar
EvoM Community Team
For anyone looking for info on the 2byte-> 1byte load see here:
https://www.evolutionm.net/forums/sh...d.php?t=347621
Looks pretty sweet!
Old Jun 4, 2008 | 11:24 AM
rallykid's Avatar
any chance to include lean spool disable/enable ?
Old Jun 6, 2008 | 12:30 PM
alan678's Avatar
Originally Posted by tephra
- simplified code + removed redundant code.
Any hope on the ROM space issue for the 96940011 guys?
Old Jun 6, 2008 | 12:41 PM
l2r99gst's Avatar
I think since 96530006 works, there wasn't any plan to look at 96940011 anymore, but I could be wrong.
Old Jun 6, 2008 | 01:43 PM
mrfred's Avatar
tephra ROM not needed for that. All that's needed are an updated definition file which should be released with the next version of ECUFlash.
Old Jun 16, 2008 | 01:03 AM
tephra's Avatar
ok I have done up a 88590015 v5.8 rom.
please be aware that you will need to delete your old XML
also this is totally untested, so again follow the usual precautions when flashing this to your car
notes:
* avg map replaces the original variable - if you want to log the original please log 0xFFFF8417
* ditto for the rear 02, so log 0xFFFF8409 for the real variable
* 0xFFFF840B has the 2byte->1byte variable so log that and then in evoscan multiple the "x" by whatever factor, ie by default use Eval="1.2*x"
88590015 - V5.8 TEST
Old Jun 16, 2008 | 01:27 PM
Tek3Evo's Avatar
I don't see the ThrottlePercentage scaling defined in this file as it was in V5 but it is used in definition for "NLTS TPS Threshold"
Old Jun 16, 2008 | 01:38 PM
Tek3Evo's Avatar
mrfred,tephra
What variable would be used for mrfred direct boost control with MAP averaging turned on/off?
Old Jun 16, 2008 | 03:55 PM
tephra's Avatar
Tek:
1) feel free to put in the scaling - it will be included in the new version of ecuflash.
2) just use the same variable as before, with map avg enable OR disabled this variable is the one to use
Old Jun 16, 2008 | 07:41 PM
fostytou's Avatar
EvoM Community Team
Tephra, your pm box is full and This is semi-relevant:
Logging at the track tomorrow!
Let me know by early morning if there is any specific action or item you want me to log going around autobahn south for you tomorrow. I plan to grab a complete ~10 min session of rpm, load, airflow, fuel, boost, and a few other things.
Leaving at 630, I'll check my pm/email beforehand
Old Jun 16, 2008 | 07:46 PM
tephra's Avatar
I would ensure the car drives normally before dumping huge loads on it
please take care when testing this, its highly possible I have missed something
