Evo 10 - Ecuflash - 3 tables
Old Jun 12, 2008 | 04:13 AM
  #106
gunzo's Avatar
If you use m32176F4 .. you get only a partial decode .. if it's m32196 .. then probably that's the reason we can't get a full decoding ..
&h50000 seems to be the start of the data code ..
&h55000 seems to be the start of the 2D and 3D tables ..
It is very similar to the SH2 processor code .. problem is if we need to continue further .. the processor must be known and if the current disassembler can support the chipset ..
Old Jun 12, 2008 | 07:28 AM
  #107
mrfred's Avatar
Yep, jcsbanks and I both did that. I went in and searched out some sections of code that were not auto-disassembled when starting at the entry point, and found that there are occasional word-length hex values that cannot be auto-disassembled using any of the available M32R processor variants. The m32196 product description suggests it uses an expanded M32R language. I think that is the problem we are having, but I also cannot find a software manual for the m32196 to confirm. There is no listing on the m32196 product pages.
Old Jun 12, 2008 | 08:25 AM
  #108
Chabada15's Avatar
can someone give me a quick explanation of the difference from a 2D table to 3D? i mean i know the literal difference but im saying in conjunction with ecuflash?...i never messed with assembly language ive only ever programmed in C++ and VB (highschool lol) so i understand whats going on but not completely...sorry for off topic question
Old Jun 12, 2008 | 08:34 AM
  #109
mrfred's Avatar
2D = data vs one independent variable, e.g., baseline WGDC vs RPM.
3D = data vs two independent variables, e.g., fuel or timing tables.
Old Jun 12, 2008 | 03:46 PM
  #110
Chabada15's Avatar
so in your example fuel for instance the variables are rpm, load, and target AFR in the table? im sorry im just trying to understand this a little better
the data would be where in-between those 2 variables the car is actually at?
Old Jun 12, 2008 | 04:22 PM
  #111
mrfred's Avatar
In a fuel table, RPM and load are the independent variables. AFR is the dependent variable that gets adjusted.
The axes' values (in this example, the RPM and load values) are stored in a different location in the ROM than where the AFR values are stored. Not sure if that answers your question. I'm a bit confused as to what you are asking.
Old Jun 13, 2008 | 04:17 AM
  #112
Toxin's Avatar
Why oh why did I look into this thread. Looking at X prices now
Awesome work guys.
Old Jun 13, 2008 | 04:28 PM
  #113
Chabada15's Avatar
nope you answered it perfect MRFred thank you i completely understand it now
Old Jun 13, 2008 | 04:48 PM
  #114
SoCalRedLine's Avatar
just read the whole thread.... GOOD JOB GUYS! this is friggin awesome.
If i could understand hex and binary... id be trying to help dissasemble. Ill stick to what i know...tuning cars with available tables .
definately getting the 2.0 cable when it comes out.
subscribed.
Old Jun 18, 2008 | 09:32 PM
  #115
StevenStarke's Avatar
how we doin?
Old Jun 19, 2008 | 08:42 AM
  #116
jcsbanks's Avatar
We have the code disasssembling without errors.
I've not had any time to do any more on it, too busy with house renovation.
Old Jun 19, 2008 | 08:58 AM
  #117
TTP Engineering's Avatar
Have any volunteers wanting to take a trip to the UK to help Banks finish his renovations?
Old Jun 19, 2008 | 09:10 AM
  #118
mrfred's Avatar
We've got the same disassembly base code, but I'm in a similar situation (baby instead of house). I probably won't do much with the X stuff until I get flex fuel working on the IX. Colby has the same disassembly base code, so hopefully he will take some time to seek out the main tables.
Old Jun 19, 2008 | 09:15 AM
  #119
Funny because i'm in the middle of doing renovations AND we just had a baby 5 days ago! But i'm no help anyway with this code disassembling. I'd do better with an etch a sketch
Old Jun 19, 2008 | 02:15 PM
  #120
mrfred's Avatar
Congratulations, and you have your hands full!
