TephraMOD V5.10
Old Sep 26, 2008 | 01:07 PM
  #331
KOTT's Avatar
tephra, have problen with nlts
use rom 94170015
when ntls is enabled(no lift to shift = 1) and i change gear on redline rpm with lift i have something like one-two second fuel cut after changing gear(injector pulse=0% in this moment and full thortle(thortle opening=100%))! but when i change gear with out lift(fast shifting) all is normal! any fuel cut
when ntls disabled(no lift to shift = 0) and i change gear on redline with lift i also havn't any fuel cut...
why when ntls enable after change gear with lift(only on hi rpm) i have fuel cut??? help pls
Old Sep 26, 2008 | 01:10 PM
  #332
fahdc's Avatar
can anyone help with ROM ID of EVO8 JDM 2003 with the XML - i would appreciate the support ;
Old Sep 26, 2008 | 02:20 PM
  #333
greek_evoVI's Avatar
use rom 94170015
move your foot from the clutch petal man
Old Sep 26, 2008 | 02:46 PM
  #334
Jack_of_Trades's Avatar
+1, everyone goes thru this lol. If your shoe even REMOTELY is resting on the pedal, the clutch switch is activated and causes fuel cut (the whole point of the NLTS) just get used to FULLY removing your foot between shifts, it takes some getting used to.
  #335
MR Turco's Avatar
use rom 94170015
What program is that?
Old Sep 26, 2008 | 04:06 PM
  #336
fahdc's Avatar
Old Sep 26, 2008 | 08:24 PM
  #337
KOTT's Avatar
most interesting that i hadn't it earlier... it sudenly begins...
Old Sep 26, 2008 | 08:27 PM
  #338
tephra's Avatar
yeah - if you are not happy with the engagement/disengagement postion of the clutch you can adjust it - a bit...
another option is to use some foam on the pedal where the swtcih touches.. this increases the throw of the switch...
Old Sep 27, 2008 | 12:21 PM
  #339
ahagge's Avatar
"Fuel Economy" Alt Map?
I'd like to implement the TephraMOD alt-map switching, but I'd like my alt map to be tuned for maximal fuel economy. I'm a noob at this, but from the "Economy Tuning" thread, I understand that I'll need to modify both the fuel maps AND the "Open Loop Load" maps (to force the ECU into "Open Loop" mode so it runs off the maps, right?).
Does the TephraMOD alt-map switching allow me to switch the "Open Loop Load" maps as well as the fuel maps? If not, is it even possible to add these maps to those that can be switched?
Apologies if I'm asking a "stupid noob question". I'm just trying to find ways to bump up my commuting fuel economy on this lame Calif. 91 octane swill...
Old Sep 27, 2008 | 04:28 PM
  #340
SWOLN's Avatar
I installed this and went for a tune. I have all the 1's and 0's for the Tephra mod area seems like all is fine. I am getting some pretty good knock/ timing retard on tip in. Is there something that I missed ? I've used the Lean Spool before and now realize there is no Enable/Disable box to check. They are both set at 1500 like previous. I noticed there are other options in the lean spool area, were the values changed? Thanks
Old Sep 27, 2008 | 04:38 PM
  #341
Options....in the...leanspool area??? Enable/disable check box??? I'm lost.
Old Sep 27, 2008 | 04:39 PM
  #342
SWOLN's Avatar
Thanks for responding on Saturday Jack. I thought there used to be a box to check? No?
Old Sep 27, 2008 | 05:38 PM
  #343
KOTT's Avatar
stil have problem(
Old Sep 27, 2008 | 08:13 PM
  #344
stil have problem(
have you adjust the pedal?
set your nlts lower and see at what pedal position it switches on to be sure...
otherwise you can put a external switch to the clutch button wire to turn it on/off manually
Old Sep 27, 2008 | 09:06 PM
  #345
What are your boost cut tables set to KOTT? Have you removed your throttle body or messed with your TPS at all? If the TPS was the problem the car would just over-rev if it was dis-engaging the NLTS right? The problem is its ENGAGING the NLTS, either that or something else is triggering fuel cut. The boost cut tables are the only thing that realistically would do that other than the NLTS.
