New Maps for Evo 7 and 9
Old May 9, 2009 | 06:05 PM
  #316
Danieln's Avatar
Originally Posted by Ted B
Has anyone resolved the Decel Fuel Cut Delay and Cooling Fan maps for 94170015?
Any chance of having these for 88840017?
Thanks!!!
Old May 9, 2009 | 06:31 PM
  #317
Deepnine's Avatar
Thermofan for 88840017 should be:
<scaling name="Percent (128)" units="%" toexpr="x/1.28" frexpr="x*1.28" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
<table name="Thermo Fan Duty - Stationary" category="Thermo Fan" address="5114" type="3D" level="3" swapxy="true" scaling="Percent (128)">
<table name="Thermo Fan Duty" type="Static X Axis" elements="3" scaling="RPM">
<data>_On_</data>
<data>A/C1</data>
<data>A/C2</data>
</table>
<table name="Engine Temp" address="713A" type="Y Axis" elements="12" scaling="Temp"/>
</table>
<table name="Thermo Fan Duty - Moving" category="Thermo Fan" address="4036" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<table name="Thermo Fan Duty" type="Static X Axis" elements="9" scaling="Load">
<data>ON>22km/h</data>
<data>ON>52km/h</data>
<data>ON>82km/h</data>
<data>AC1>22km/h</data>
<data>AC1>52km/h</data>
<data>AC1>82km/h</data>
<data>AC2>22km/h</data>
<data>AC2>52km/h</data>
<data>AC2>82km/h</data>
</table>
</table>
Old May 9, 2009 | 06:36 PM
  #318
Danieln's Avatar
Thank you so much ......
It`s so hard to look for new updates for these roms....
I appreciate a lot this!!!
Take care
Old Aug 1, 2009 | 08:19 PM
  #319
logic's Avatar
Originally Posted by Mattjin
***** WARNING *****
DO NOT ADJUST THESE MAPS UNLESS YOU KNOW THEIR EXACT PURPOSE. IF YOU DO ADJUST THEM INCORRECTLY IT IS HIGHLY LIKELY YOU WILL BURN OUT THE COILS. DON'T SAY YOU HAVEN'T BEEN WARNED.
Same warning applies to this post, for the record. For 96530006-based ROMs:
PHP Code:
<table name="Ignition Coil Charge Time" category="Timing" address="41ea" type="2D" level="2" scaling="uint8">
    <table name="Battery" address="6808" type="X Axis" elements="9" scaling="BatteryVoltage"/>
</table>
<table name="Ignition Coil Charge Time (Unknown 1)" category="Timing" address="41fa" type="2D" level="2" scaling="uint8">
</table>
<table name="Ignition Coil Charge Time (Unknown 2)" category="Timing" address="420a" type="2D" level="2" scaling="uint8">
</table>
Old Oct 5, 2009 | 06:47 AM
  #320
MR Turco's Avatar
can someone direct me to the latest Decel Fuel cut tables for 88590015? The tables i have look incorrect.
Also, has anyone had luck messing with the decel stuff to combat throttle hang?
Old Oct 5, 2009 | 06:54 AM
  #321
mfr122887's Avatar
+1
I am looking for setings to help get rid of the throttle hang on 96530006
Old Oct 5, 2009 | 07:04 AM
  #322
Appauldd's Avatar
What adjustments would you make to the decel tables to eliminate the throttle hang?
Old Oct 5, 2009 | 07:09 AM
  #323
MR Turco's Avatar
Not sure. I would think there is some sort of timing depending on what load you are at when you let off the throttle. I have seem the ISCV sit steady until a certain RPM then drop off. the ISCV stuff doesn't seem to change it so i would assume there is something adding ISCV steps until a certain point.
Old Oct 5, 2009 | 10:14 AM
  #324
l2r99gst's Avatar
Search the thread for the ISCV tables that mrfred found...I posted them up for 96530006. There are two that are RPM based. Maybe try playing around with those two to see if it has any effect.
Eric
Old Oct 10, 2009 | 11:37 AM
  #325
JohnBradley's Avatar
Dwell tables for 9417? I guess I didnt read this thread as well as I thought I had before. Now there are only 2 things left on my list
Old Oct 10, 2009 | 12:36 PM
  #326
94170015 uses the same charge access unit, the battery axis is incorrect vs the 96530006. I am sure thats just a matter of messing around till you find something that looks right.
The "unknown 2" table looks like it is vs crank position and thats why it has all 96 values, the "unknown 1" might be trailing edge data/rising edge data?
Old Oct 10, 2009 | 12:47 PM
  #327
Its 0x65ec
Old Oct 11, 2009 | 03:11 AM
  #328
merlin.oz's Avatar
bump
Doing some work on the 93660005 rom, so popping this thread back into circulation to get at it easily.
Boosted Tuning
Aug 26, 2023 10:14 PM
PPM
Apr 2, 2015 09:35 AM
mrfred
Dec 21, 2014 10:13 AM
Pd1
Oct 11, 2009 05:17 PM
Mattjin
May 9, 2009 08:40 PM
