highest MAF Hz logged with stock MAF?
Old Oct 12, 2008 | 08:44 PM
mrfred's Avatar
What's the highest MAF Hz that you've logged with the stock MAF? I need to know how high it can go for a patch that I'm working on.
Old Oct 12, 2008 | 09:51 PM
RazorLab's Avatar
Highest I have logged so far is 2985hz
Old Oct 12, 2008 | 10:02 PM
tephra's Avatar
2byte airflow? ~1900 hz
what turbo is that Bryan?
Makes my 1900 seem a bit lame
mchuang's Avatar
dam highest i logged was 1900 and some change. Still on stock 9.8
Old Oct 12, 2008 | 11:33 PM
RazorLab's Avatar
It's a PT6262 on E85
My personal evo is 2199hz or so on FPgreen
Old Oct 13, 2008 | 06:41 AM
gsrboi80's Avatar
2byte-2341/2342
PT61mm BB
Old Oct 13, 2008 | 08:15 AM
mrfred's Avatar
That's impressive. What was the whp?
Old Oct 13, 2008 | 08:19 AM
MalibuJack's Avatar
I've been able to artificially get over 3000hz, but the highest I've seen with my specific turbo and a stock MAF was around 2900hz, Since I run a blowthrough MAF, I actually have the settings calibrated to be alot lower even though boost is very high.
Old Oct 13, 2008 | 08:34 AM
C6C6CH3vo's Avatar
Stock charger with 10.5cm2 WG housing. MAF is upside-down and use HKS pipe and filter which, both change the signal quite a bit. My 2byte air readings are jagged for some reason and when smoothed appear up to 200hz higher than real. The actual frequency from meter (ssi4) averages about 1830hz but have seen mid 1900's with higher WG preload and less performance.
Old Oct 13, 2008 | 10:10 AM
RazorLab's Avatar
470 on our dyno. That was at 26.5psi up top. It maxed out the fuel system. It would have done more at 27+ but it didn't have the fuel.
Old Oct 13, 2008 | 10:17 AM
mrfred's Avatar
Thanks everyone. Got the info I needed.
Old Oct 13, 2008 | 04:55 PM
fixem2's Avatar
Any info on the patch you are working on MrFred?
Old Oct 13, 2008 | 05:16 PM
mrfred's Avatar
Its nothing earth shattering, but will be handy for judging performance and fuel economy. Can you guess from that? :-)
EvilEvolution8
Dec 18, 2015 12:02 AM
GST Motorsports
Aug 17, 2009 01:04 PM
EvoooB
Mar 30, 2009 06:26 AM
cpoevo
May 3, 2007 08:22 AM
TrinaBabe
Nov 1, 2005 07:32 AM
