disable P0300 test
Old Nov 16, 2009 | 02:29 AM
  #211
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by mrfred
Yes.
Hmm my CEL was still on. But I know it's the P0300
Old Nov 16, 2009 | 05:35 AM
  #212
mt057's Avatar
I had to use a code clearer to get rid of mine after I flashed it. I found my fuel trims to be the same way.
Old Nov 16, 2009 | 06:01 AM
  #213
05blue8's Avatar
Has anyone noticed side effects of disabling the P0300? Mine caused throttle hang. I had mrfred look at the logs and it appears that in some roms the P0300 is connected to something that can and does cause throttle hang. I'm on the 96940011 ROM. Anyone else see this?
Old Nov 16, 2009 | 06:47 AM
  #214
Mellon Racing's Avatar
I have the same rom and don't have throttle hang with p0300 disabled. I dropped the bomb on the ROM and disabled all of the cel though so that might be the difference. Usually throttle hang is due to an improper idle rpm setting
Old Nov 16, 2009 | 07:04 AM
  #215
mrfred's Avatar
I guess Evo 8s might require clearing the codes. With my 9, the codes would always clear when I flashed a new tune. EvoScan can clear codes.
Old Nov 16, 2009 | 07:07 AM
  #216
I've also noticed that some cars don't clear codes or even fuel trims on a flash.
Old Nov 16, 2009 | 07:20 AM
  #217
05blue8's Avatar
Hey Mellon, I talked to mrfred about it and sent him some logs also. When I load up the P0300 disable and all I've done is changed the bit from 1 to 0 for bit 4 the hang starts. I load back up my old ROM and it's back to normal. mrfred thought it might require more digging so wanted em to post up here to see if anyone else had any insight into it. I could try some more disabling and see if that matters also. What all CEL's did you disable in yours? Thanks!
Old Nov 16, 2009 | 07:36 AM
  #218
DBallz's Avatar
Still very new to evo flash and evoscan. So I'm trying to find where evoscan clears codes. Anyone?
Old Nov 16, 2009 | 07:42 AM
  #219
all of them
Old Nov 16, 2009 | 07:49 AM
  #220
mt057's Avatar
I think its at the bottom right hand corner it will have a display "dtc" or something. You can use that same box to check your cars codes as well as clear them.
Old Nov 16, 2009 | 11:30 AM
  #221
DBallz's Avatar
Ahhh thanks
Old Nov 19, 2009 | 08:50 PM
  #222
darkside4G63's Avatar
help! i am trying to save the amended xml and my computer will not let me. i opened my rom metadata with notepad, pasted the patch to the end of the file and ever time i try to save it my computer pops up a window saying that it cannot save and to check the path or file name. im pissed. im so computer retarded. any help please?
Old Nov 23, 2009 | 08:16 PM
  #223
Rex915's Avatar
good info
Old Dec 2, 2009 | 07:21 PM
  #224
sikwititevo9's Avatar
does this only work for the evo 8's? or can it work for the 9's also? another thing once you change this will the car still pass emissions?
Old Dec 2, 2009 | 07:49 PM
  #225
JohnBradley's Avatar
After this do the force OBD2 pass and its no worries. This by itself will pass though.
