The stock ECU has gear dependent boost control!
Old Dec 2, 2008 | 08:24 AM
  #166
mrfred's Avatar
Originally Posted by Deepnine
What happens when clutch is slipping?
My recollection is that nothing happens while the clutch is pressed, but someone needs to verify.
Old Dec 2, 2008 | 01:25 PM
  #167
Deepnine's Avatar
I mean what happens if the clutch is worn out and starts to slip when clutch is depressed. It might get errors and nobody will know why boost does make strange things. Some error routines witch shuts off boost might be good.
Old Dec 2, 2008 | 01:51 PM
  #168
wshihdnevo's Avatar
This is all very interesting!
Old Dec 2, 2008 | 02:33 PM
  #169
tephra's Avatar
if you clutch is slipping then boost control is the least of your problems.
Old Dec 2, 2008 | 03:12 PM
  #170
Deepnine's Avatar
I had the problem with slipping clutch only at peak torque at cold weather, i wasn't feel anything. I just found out by viewing my logs, with gear based i might had problems and had bought a bigger turbo than a better clutch
Maybe boost cut off is to extreme, but whats about a new error code?
P9999 - rpm/kph ratio missmatch
this will show wrong rpm/kph setting.
I don't know how difficult a new error code is, or if someone everlooked deeper at the error code routines. It is just an idea from a guy who has to much free time now. It's winter, car is in the garage untill april. Parts are orderd but not here yet.
Old Dec 2, 2008 | 03:40 PM
  #171
tephra's Avatar
but how do you know the rpm/kph ratio is wrong? there are no other inputs to verify the system.
anyways I tested the new system a little this morning, and the gear still jumps a tiny bit - I will post up a graph later today - but I am still thinking of averaging out the ratio variable...
Old Dec 2, 2008 | 11:53 PM
  #172
tephra's Avatar
hrmm I am not sure whats going on here, even with my averaging forumla i am still getting stuff ups.
HOWEVER when I run the math by hand (ie manual rpm/speed from evoscan) it works fine... I am thinking of ditching that variable and just make our own rpm/speed...
Old Dec 3, 2008 | 12:28 AM
  #173
Deepnine's Avatar
if the rpm/kph has a other value over a given period than defined in the table.
for example:
if ratio table says: 40, 50, 60, 80, 120, 170
and you get another value, but if the ratio is still jumping, it won't be able to be very accurate. so it was just an idea, now we can ignore it
I haven't thought enough about it.
Old Dec 3, 2008 | 02:11 AM
  #174
tephra's Avatar
mmm that would be ok if the ratio variable wasn't so coarse
lets get the system working first then we can enhance it
Old Dec 6, 2008 | 04:45 AM
  #175
evoIXcencal83's Avatar
this is true . in first through third i run 21 psi.for fourth and fifth i run 24 psi.ecu controlled boost.
Old Dec 6, 2008 | 06:46 PM
  #176
tephra's Avatar
Alright I am pleased to announce the gear based boost control works fully
Thanks John and Deepnine for your ideas
Back on the path to getting a TephraMod release out soon
Old Dec 7, 2008 | 02:53 AM
  #177
Deepnine's Avatar
Ideas don't make the work, they just make more work for you.
Thanks for you effords, i can wait until the winter is gone and the car is on the street again.
Old Dec 8, 2008 | 05:43 AM
  #178
dudical26's Avatar
great news, thanks for your hard work.
Do you think you will incorrporate mrfreds lb/min logging and his wideband replacement for both the front and rear 02 sensors.....pretty please.
Old Dec 8, 2008 | 05:59 AM
  #179
MR Turco's Avatar
This is going to be quite the next patch. The only feature i am still interested in is having NLTS on/off using the gas pedal like the valet mode.
Old Dec 8, 2008 | 06:06 AM
  #180
tephra's Avatar
ill take a look at the lb/min logging dudical.
Mr Turco - yeah I will *try* and get that in as well...
