Air Temp Compensation table
Old Jan 7, 2009 | 12:45 PM
  #136
honki24's Avatar
Originally Posted by l2r99gst
Well, I don't know all of the details as well as mrfred or jcsbanks who have or are going through the ECU code, but the ECU calculates the mass airflow and then the injector pulsewidth is calculated based on that. The mass airflow incorporates temperature and baro.
So, I don't know if there are specific tables that do exactly what you are looking for, but temperature is accounted for in the mass calculations. There seems to be additional trims for timing for excessive conditions, where timing may be pulled a few degrees for IAT (tables already found and posted), for example.
Thanks for clarifying that a bit more. At any rate though I think our frustration is that we're not finding a table that will adjust mass airflow only based on the IAT. This table we have muddies the water by adding in baro compensation as well. We're hoping for individual adjustment tables. I'm no code writer but I can't imagine that being difficult. (making two separate tables that multiply together that result in something like the table we have now).
Old Jan 7, 2009 | 12:49 PM
  #137
honki24's Avatar
On another note and since it doesn't seem a more direct table will be found any time soon:
Is there someone willing to write a scaling that would display the horizontal axis in degrees F?
From my calculations the current entries equate to approximately the following:
.78 = 180F
.91 = 106F
1.03 = 33F
1.28 = -40F
I hate to ask someone to do this but I really can't even fathom where to start.
Old Jan 7, 2009 | 05:18 PM
  #138
l2r99gst's Avatar
What do I get if I write a scaling for you to display degrees F? It shouldn't be too difficult.
Anyway, if I do this for you, you have to absolutely understand, that it will be for one particular baro value (like 1atm). As long as you completely understand this and know that the axis is really air density, then you should be ok. I read through this thread again and noticed that mrfred said the axis is air density and mentioned it is IAT/baro, but density should be baro/IAT. PV=nRT, n/V=P/RT. Maybe the axis is the inverse.
Anyway, either way, I should be able to write some sort of scaling to show you the degrees F, even though that is completely wrong.
Old Jan 7, 2009 | 07:17 PM
  #139
D-VO's Avatar
.78 = 180F
.91 = 106F
1.03 = 33F
1.28 = -40F
Eh? I thought .53 = 180F and .78 = 106F. Did I miss something?
Old Jan 8, 2009 | 07:12 AM
  #140
l2r99gst's Avatar
Anyway, either way, I should be able to write some sort of scaling to show you the degrees F.
Actually, I started working on this and I was getting different numbers than mrfred has posted. So, there is an error in my math somewhere. If I get it figured out, I will post it up.
Old Jan 8, 2009 | 07:32 AM
  #141
mrfred's Avatar
The conversion from temperature to "density" units is taken from another table. Its not from PV=nkT.
Old Jan 8, 2009 | 07:44 AM
  #142
l2r99gst's Avatar
Ah, that would explain it then. I checked my math a number of times and just couldn't come up with the same numbers as you. But, of course I was using PV=nRT.
MY math had the values following the chart that was posted earlier, I think from honki. This table in the ROM seems to be overcorrected by a factor of around 2, roughly, in terms of density at a specific temperature. For example, if I used the axis as density and standardized 32F =1, then the axis would have been (for 1 atm) from .77 to 1.17 (180F to -40F).
Old Jan 8, 2009 | 08:43 AM
  #143
03whitegsr's Avatar
It seems like the ECU is standardized around 25C from some of the other tables in the ECU.
Old Jan 8, 2009 | 11:17 AM
  #144
honki24's Avatar
Understood. The x-axis absolutely is NOT temperature, but a sort of representative density. I am okay with knowing in the back of my mind that the temps are only defined for P = 1atm.
I can paypal you $1.04 (to cover paypal fees)
Old Jan 8, 2009 | 12:45 PM
  #145
l2r99gst's Avatar
I stopped trying once mrfred mentioned that the relation was from a lookup table and not PV=nRT.
Old Jan 8, 2009 | 01:07 PM
  #146
l2r99gst's Avatar
honki24,
I want it all in pennies in a brown paper bag left on the porch.
Here you go:
Code:
<scaling name="AirTempBaroFactor1atm" units="F" toexpr="-4.5813*x+335.46" frexpr="(x-335.46)/-4.5813" format="%.0f" min="-40" max="335" inc="1" storagetype="uint16" endian="little"/>
You may need to change the endian depending on which version of ECUFlash you're using.
If you use this scaling, maybe rename the X axis in the map to something like 'deg F for air density change at 1atm' or something similar to remind you. Maybe just add the table again with the new changes so you can keep the correct scaling that mrfred gave.
Eric
  #147
03whitegsr's Avatar
Mrfred, can you post the look-up table?
Old Jan 8, 2009 | 01:53 PM
  #148
honki24's Avatar
honki24,
Eric
No problem. Just post your home address on the internet!
Thanks man. Wish I understood some of this coding better... lol no time to learn though.
So, to change the x-axis values I can just go ahead and put in these cells whatever I want, right? Like 120F, 100F, 50F, 30F for example?
Old Jan 8, 2009 | 02:07 PM
  #149
l2r99gst's Avatar
I thought that was mentioned by mrfred to not be a good idea?
The interpolation is linear between the cells, so why not just use the scaling as it is? Is it because you want a non-linear correction?
Old Jan 8, 2009 | 04:13 PM
  #150
mrfred's Avatar
Correct. Do not simply insert temperature values in the axes.
