The definitive EcuFlash Evo 10 thread
ECUFlash 1.41 released EVO X CAN Support
http://openecu.org/index.php?title=EcuFlash
2009-01-29: Version 1.41 released
* -- EcuFlash Related Changes --
* add support for EVO X CAN reflash
You will most likely need Microsoft Service Pack 3 if you don't already have it.
I think its safe to assume that this is a major release. Damn! just look at the number of fixes and added new features!!!!!
Finally, I can start putting my OP 2.0 cable to some use, if I can remember where I put it
Well I encountered a problem....I have a ECU that has been Works Flashed and it appears locked as it gives an error every time I try to read the ECU. Anyone know any more? Can you flash over the Works? I don't want to try and flash over a Works tune without knowing compatibility issues.
ecutek locked the ecu with evo 8 and 9. if thats how you had it tuned, its likely its also locked for the evoX. however there was a simple work around that malibujack made for the 8/9 to unlock it.
