22 psi Boost setting for stock turbo
Old Feb 18, 2009 | 06:16 PM
03RRVIII's Avatar
Question 22 psi Boost setting for stock turbo
i just installed a 3port GM Boost Selenoid, this is on a stock turbo VIII. i need to set the boost to 22psi as how it was set on my MBC, can you show me your boost setting for 22 psi that i can use to start with
TIA
Old Feb 18, 2009 | 10:16 PM
mlocatel's Avatar
https://www.evolutionm.net/forums/ec...-solenoid.html
Try this post
Old Feb 19, 2009 | 11:52 AM
03RRVIII's Avatar
but it would be a lot easier if I can use someones boost maps, and adjust from there, cause coming from a MBC my maps are all set to 0
Old Feb 19, 2009 | 12:22 PM
mlocatel's Avatar
As far as I remember there should be examples in there.
If not, there are other posts with examples... I don't remember exactely hich one.
Try with the search boost map
Old Feb 19, 2009 | 06:18 PM
03RRVIII's Avatar
Originally Posted by Diddy69Art
someone post his wgdc settings on this post,
https://www.evolutionm.net/forums/ec...olenoid-3.html
try this one, but be carefull...
regards, Diddy
thanks ill try those .......
Old Feb 21, 2009 | 09:46 AM
THUB's Avatar
This gave me about 21-22 PSi at around 70 degrees. The temperature has been raising hell and overboosting in the cold, though. The BCLO and MWGDC are pretty good. Keep in mind every car will be different, sometimes wildly so.
Attached Thumbnails 22 psi Boost setting for stock turbo-boost-control-tables.gif
evo86
39
Mar 24, 2014 11:50 PM
Evo8*
Jan 4, 2012 08:12 AM
tenaciousd199
15
Apr 26, 2009 01:48 PM
burgers22
Jun 30, 2006 09:17 PM
stvbreal
13
Apr 9, 2003 05:14 PM
