TephraMOD V6 - testing!
Old Apr 22, 2009 | 09:52 PM
  #541
tephra's Avatar
no probs
Old Apr 22, 2009 | 10:06 PM
  #542
nano's Avatar
Think I found a problem of sorts....my XML definition files may be mucked up from old installs and fooling with different mods, I don't have an Alternate Wastegate Duty table, only a Base one. Let me double check all my definitions.
If that is the problem im going to kick myself haha!
Old Apr 22, 2009 | 10:14 PM
  #543
tephra's Avatar
didn't you just copy the tephramod-88590615.xml into the ecuflash directory?
you shouldn't have need to change it (except for direct boost rescalings)
Old Apr 22, 2009 | 10:29 PM
  #544
nano's Avatar
Correct, I believe it was from the downloaded pre-modded 88590615 (with directboost and JDM MAP) files from the stock ecu wiki.
Fresh xml files under misubishi/evo along with the new v6 xml looks like the left, what I had is the right.
Going to go through and re-mod it with directboost and JDM MAP and copy over my data and try it again!
Old Apr 22, 2009 | 10:35 PM
  #545
tephra's Avatar
ok - i checked the code and the normal wgdc + altmap wgdc are NOT swapped around, so you should still be good to go
Old Apr 22, 2009 | 11:03 PM
  #546
fostytou's Avatar
EvoM Community Team
Direct boost is definitely working for me (and on the correct labels)
Did you do the actual mods to the rom or just the XML? I'd double check those.
Old Apr 23, 2009 | 10:12 AM
  #547
nano's Avatar
Ok, last night I re-installed EcuFlash, along with fresh definitions for the v6 mod....along with adding the correct JDM Map definitions and Direct Boost defs.
Changed all of the proper settings for both mods, double checked them after.
Changed my 3d baseline boost table to psia8 scaling and put in my values. 14.7 Boost Adder Value. My WGDC=100% under this load is set to 100.
This morning flashed the car, popped the hood checked my boost lines on my 3port to eliminate that as the problem....
Went to boost and same damn problem
Here is a very short 3rd gear log.
Old Apr 23, 2009 | 12:52 PM
  #548
fostytou's Avatar
EvoM Community Team
I'm really not trying to be a jerk, the same thing happened to me with similar symptoms, but go over the direct boost control thread with a fine toothed comb. Mine was acting similar the first time I had done it and I had missed one of the pointers/hooks. Make sure you read both parts where the information is at, I think some of it is split up.
Old Apr 23, 2009 | 04:18 PM
  #549
tephra's Avatar
hrmmm...
you should STILL be getting wgdc from the bwgdc map thou... since your getting 0 something else is going on.
nano - email me your rom, i will check out some bits of it myforumname at gmail.com
Old Apr 23, 2009 | 05:55 PM
  #550
nano's Avatar
Ok, so I don't have a log, but I overboosted today on the way home from work 25psi....so im guessing it IS working....its just one of my settings must be off. Not sure which, maybe the 100% WGDC setting needs to be lowered or something. Will adjust and hopefully try and get back out on the road tonight to test.
Old Apr 23, 2009 | 06:42 PM
  #551
tephra's Avatar
yeah you can't overboost with 0 WGDC.
we really need a log to see whats going on (obviously :P)
Old Apr 24, 2009 | 07:45 AM
  #552
tephra's Avatar
Phenem - how did the fix go for you? for V7T1 couple pages back -
Old Apr 24, 2009 | 07:47 AM
  #553
MR Turco's Avatar
so i was considering loading V6 on today but should i just wait for V7? sounds like it will have some sweet new features.
Old Apr 24, 2009 | 07:50 AM
  #554
tephra's Avatar
V6 works and should be bug free.
V7 will probably be out in a couple of weeks (sooner if I drop the launch-map mode)
Old Apr 24, 2009 | 07:51 AM
  #555
phenem's Avatar
Sorry man I have been really busy, I am an IT Consultant and we are in the middle of the huge install this week and weekend. I won't be able to test anything most likely till Sunday or Monday. I will report back with logs and results...
