TephraMOD V6 - testing!
Old Apr 30, 2009 | 07:08 PM
  #601
tephra's Avatar
sorry dude.
you might as well hold of until i release the launch-altmap thing.. should be done soon for testing that is
Old Apr 30, 2009 | 07:27 PM
  #602
nonschlont's Avatar
edit: wrong thread...
Old Apr 30, 2009 | 07:59 PM
  #603
tephra's Avatar
UPDATE: V7T5 is up
96530706-V7-test5
1) It includes launch-map mode. This should be fairly self-explanatory to you guys
2) IT HAS A DIFFERENT XML - so through out the old file
3) V7T4 is pretty stable, V7T5 is possibly not.
Can I get some people to test it out and let me know how it goes?
This will hopefully become the final version - so any little adjustments to the default TephraMOD values you guys think would be good - let me know
Again - let me know of anything that you would like changed for the Final
Old Apr 30, 2009 | 08:38 PM
  #604
nonschlont's Avatar
ok well, I just noticed something w/ v.6 I just re-introduced my corrections, but Im not getting any positive correction... Heres a 5th gear pull from today, and I have another showing no correction.
Note: I just started working on my 5th gear, and just had a 15 to 20* temp. change, (warmer) so its not exactly on point just yet.
my set up:
-3.1 0
-2.5 2.0
-2.0 1.5
-1.5 1.0
-1.0 .5
-0.8 .5
-0.5 0
-0.3 0
File Type: zip
Old Apr 30, 2009 | 08:40 PM
  #605
tephra's Avatar
is your "max upward correction" table zero'd out?
Old Apr 30, 2009 | 08:43 PM
  #606
nonschlont's Avatar
lol... good call
Old May 2, 2009 | 07:44 AM
  #607
dan l's Avatar
So far so good for the IX v6 tephra. Except for my odd EGR valve issue where it opens on a cold start and doesn't close till about 140deg F. Gear boost works as intended. Pull boost on knock is awesome. AFR saftey also works good but you said you are going to simplify it. I've been running V6 since saint patricks day.
Old May 2, 2009 | 07:52 AM
  #608
tephra's Avatar
ok cool...
Old May 2, 2009 | 09:11 AM
  #609
phenem's Avatar
Dave, question for you on the Launch Map stuff, I have an ignition system (Dynatek) that I use as my launch control to cut ignition timing instead of using the factory (fuel cut) style launch.
I have my Stationary Launch Limit set higher than my Rev limit so I will never hit it, I have my ignition box set to 5k RPM to stutter, works perfect!
If I enable the launch maps and set my fuel/timing in the appropriate maps will it still activate and work the way I think it will although my Stationary Rev Limit is really high?
Basically does the Launch Map depend on the SRL (Stationary Rev Limit) being set low and activated (holding at appropriate RPM) for the Launch maps to come into play?
Understand my question?
~Zach
Old May 2, 2009 | 09:14 AM
  #610
tephra's Avatar
yeah i know what u mean.
launch maps has nothing todo with the SRL.
so as long as your pushing TPS > 40% or whatever i set it to, and speed < 8km/h or whatever then it will run the launch maps.
Old May 2, 2009 | 09:49 AM
  #611
phenem's Avatar
Perfect! Awesome man
I will be testing this today and let you know how it goes....
~Zach
Old May 2, 2009 | 09:51 AM
  #612
tephra's Avatar
cool
can you also test valet mode and altmap by tps (separately of course)
Old May 2, 2009 | 10:00 AM
  #613
R/TErnie's Avatar
I'm very excited for gear dependent boost control. (makes me all warm and fuzzy inside)
I'll be installing 5.10 today and getting my car up to date with the current stuff before making the switch to the v7 stuff, but I'm definitely stoked! Thank you for all of your hard work Tephra!
Old May 2, 2009 | 10:14 AM
  #614
evodood's Avatar
the patches are complete independent of each other. theres no need to install 5.1 to get to 7.
just go straight to 7 (if that's what you wanna test, keep in mind this is still early)and save yourself from all the copy/pasting and reflashing.
Old May 2, 2009 | 12:35 PM
  #615
dan l's Avatar
~Zach
Zach the ARC-2 is a spark cut style limiter with the ability to cut spark on independent channels. This is better than the fuel cut style stock launch system. Also if you have launch maps it is a moot point and adding unneeded complication to the system. If your cutting spark it doesen't matter what you have timing set to in your launch maps to a point.
