P0300 Code
Old Mar 23, 2009 | 09:09 PM
rodrig.diaz3's Avatar
P0300 Code
Sorry for my ignorance but here i go.
I have the SES light On how can i know if i have p0300 code?
The dealer diagnosis will throw this code?
Can cause damage to my engine?
My mods:
Jam stage ii 2.0 short block
gsc s2 cams
TBE
20 g turbo
06 EVO IX.
Old Mar 23, 2009 | 09:27 PM
dude's Avatar
Newer ecuflash can read codes. See what code it is, or buy a Creader off ebay for $30 bucks and plug it in and see (if you're not too savvy with tech).
Old Mar 23, 2009 | 09:49 PM
Ok i will downaload newer version of ecuflash.
Regards.
Regards.
Old Mar 23, 2009 | 09:54 PM
amui07's Avatar
you can use the tactrix cable to turn the code off too.
Old Mar 23, 2009 | 10:12 PM
There is no problem just to turn the code OFF.
This code will not damage my engine?
Old Mar 25, 2009 | 08:52 PM
How can i get the codes ?
just open the rom and go to OBDII?? and check the codes in blue?
Im right or not
Regards
Old Mar 25, 2009 | 09:01 PM
Im right or not
Regards
Old Mar 25, 2009 | 10:16 PM
Appauldd's Avatar
Go into the Periphery bits
Change FCA, bit 4, from 1 to 0
Ahhhh no more P0300
Old Mar 26, 2009 | 01:47 PM
Finally p0505 code " Idle contro system malfunction"
Something to worry about it??
Old Mar 26, 2009 | 08:20 PM
Appauldd's Avatar
Sounds like you IAC (idle air control valve) may have gone bad or is disconnected.
Pull the Throttle body off and remove the IAC and inspect the corners of the valve...if they are worn...replace it. Might help to clean it too.
Old Mar 26, 2009 | 08:22 PM
Appauldd's Avatar
To display your codes....click the "display DTC" button on EcuFlash.
Old Mar 26, 2009 | 09:25 PM
Ok thanks a lot i will try to clean up.
But is not a big issue this code?
Old Mar 26, 2009 | 09:27 PM
Appauldd's Avatar
You may have issues with stalling, and/or bad idle.
Old Mar 26, 2009 | 09:30 PM
Ok thanks again for your help and patience.
regards
mrfred
Apr 9, 2015 11:20 AM
dxlykos0131
May 7, 2014 06:15 AM
ryanholder24
Sep 20, 2011 02:57 PM
Muramasa
Mar 8, 2004 03:21 PM
