FP Red is FUN
Old Mar 26, 2009 | 12:16 AM
  #31
RoadSpike's Avatar
Originally Posted by G20
how you get 8* timing at peak 23 psi? The best I could do on my 05 is 4-5* at 23.5-24 psi peak boost and gradually increasing to 13* at 7000+ RPM with boost tapped to 19.9-20 psi (yes! for some reason my car hold boost with the MBC) before it starts knocking. This is on 91 oct as well.
To the OP, it looks like the red is holding more boost up top than the stock turbo and that may causing 5-9 knock count starting from 6500. Maybe lower boost a little bit will help get rid of that in order for you to bump up some timings.
I just lowered the timing the car is really liking this level of boost despite the low timing. I would have posted a log with the knock gone and timing lowered to acceptable levels but I ran out of time. The boost is also much higher than with the stock turbo holding around 24psi by redline as shown in the log.
I wish i knew how much the car really weighed so i could get an accurate reading on the evoscan dyno plot. I think I need to go find an AWD dyno around here and get her hooked up.
Old Mar 26, 2009 | 05:44 AM
  #32
rolly1818's Avatar
Registered User
is incresed EGTs a worry with those low timing values? just a question.
on my stock IX turbo i spiked to 26 psi and held to 22/23 to redline (sexy boost line ) and i was able to push some more timing than you are now..... we have approx. 92 octane
Old Mar 26, 2009 | 08:57 AM
  #33
RoadSpike's Avatar
I didn't see a concern with the EGT's atm I ran it once flat out in 4th and the EGT's were in acceptable levels.
This car never has been that happy with the timing even with the stock turbo not entirely sure as to the reason for that. I suppose the 92 octane is helping you too. Once e85 here becomes more readily available than 2 stations I think i'll just move this car over to the e85 crowd and really turn the boost up.
Old Mar 26, 2009 | 10:23 AM
  #34
RoadSpike's Avatar
Got a hold of Robert at FP to sum up a long email he basically stated that the two main causes of failure were:
1) Extremely high EGT number over 1700F (I'm in the good so far)
2) High boost pressures and the stock oil line can cause the thrust bearing to fail
So on both points it looks like i'm in the good. I don't run the car hard enough to get EGT's into the danger zone and my boost pressures are relatively low. Since the ultimate goal for this car is a move into e85 I plan on keeping my order for the upgraded oil line and the e85 should lower the EGT's at the higher boost.
Old Mar 26, 2009 | 10:57 AM
  #35
jcsbanks's Avatar
The one I tuned had 10% methanol, 90% 99 RON, 27.5 PSI, lambda 0.8. Timing was something like 5 mid, 15 at the top, knock sums <=3. It had a large APS intercooler, and a ceramic coated tubular exhaust manifold. None of that is a recipe for high EGTs, but the Red failed nonetheless, don't know the cause yet, not inspected, but there is excessive play on the bearing, exhaust was smoking, didn't look like overspeed on the compressor wheel apparently as it hadn't bent/filed the blade tips.
Old Mar 26, 2009 | 11:04 AM
  #36
RoadSpike's Avatar
Did you have the upgraded oil line?
I checked for shaft play before installing it and everything looked awesome.
Old Mar 26, 2009 | 11:30 AM
  #37
jcsbanks's Avatar
No, this has only come to light since this turbo was purchased and installed.
Old Mar 26, 2009 | 01:36 PM
  #38
RoadSpike's Avatar
Does sound like the stock oil line simply wasn't enough since the thrust bearing failed. Sounds like FP will be needing to require the upgraded oil lines in the future if they want to maintain a good rep.
Old Mar 26, 2009 | 02:12 PM
  #39
Motoxrider7's Avatar
Originally Posted by RoadSpike
I've heard the failures are caused by the stock oil lines not being adequate enough. I may have to contact FP and see what they suggest.
i will back you up on that. my Red just went out with a large amount of shaft play. reason is stock oil line did not give it enough oil.
i paid 560 for the rebuild from FP.
Old Mar 26, 2009 | 02:18 PM
  #40
RoadSpike's Avatar
Looks like i'll be changing out my oil line as soon as i can
Link the part i ordered.
http://store.forcedperformance.net/m...Category_Code=
They have one without filter but honestly it was a why not thing for me
Old Mar 26, 2009 | 02:21 PM
  #41
Very good idea. it will save your turbo from being destroyed. Mellon and i tuned mine with a crappy HKS bov which leaked at 25-30 psi and my boost leaks didnt help any. Now i got the FP oil line for $70 and it flows a good amount of oil. im due for another tune and shooting for 450hp. GL with your Car.
Old Mar 26, 2009 | 03:21 PM
  #42
RoadSpike's Avatar
I don't think 450whp is realistic with my mods and this fuel but with e85 stations popping up around here I think some 1200cc injectors and some corn fuel this baby will fly!
Old Mar 26, 2009 | 10:46 PM
  #43
G20's Avatar
G20
so how are your timings look now? 3-5 around 5000-6500 rpms and steadily increase to 7500? Are you able to hit 10* up top?
good work on got risk of those knocks.
Old Mar 26, 2009 | 11:20 PM
  #44
RoadSpike's Avatar
Definitely not without tripping the knock sensor.
Timing only reaches up to 8 degrees at this psi probably means i'll be forced to back off the boost as much as i hate to do that.
Old Mar 27, 2009 | 10:22 AM
  #45
RoadSpike's Avatar
Well I lowered the boost by a 2 lbs and the power dropped out... alot so I think I'll try to find a happy medium here.
