FP Red is FUN
Old Mar 24, 2009 | 10:16 PM
RoadSpike's Avatar
FP Red is FUN
This turbo rocks I'm still tuning this turbo but even with a very limited amount of time spent on just making the turbo work I can already tell that the car is much faster.
Boost is up and knock is lower despite the increased boost pressures.
Right now the boost is hovering around the 25psi mark but i think a couple pounds of boost could be had but i wont go there until I get this 25psi tuned to its potential.
I'm posting a log for you guys to see the wild progress. Full log here I do my own tuning so I don't really care if you see the timing on 91 octane.
Old Mar 24, 2009 | 10:20 PM
veilsidefd3s87's Avatar
have you dyno'd it yet to see what you put down with your current mods on 91 octane? i live in socal and use the same **** water
Old Mar 24, 2009 | 10:22 PM
RoadSpike's Avatar
Nope the car has never been on a dyno just using road tuning and evoscan to do road dyno plots for comparison. I think there is an AWD around here somewhere and i may rent it out for a few hours to see what she can make
Old Mar 24, 2009 | 10:26 PM
well thats cool. i currently have a fp green brand new and never go the chance to drop her in... so i was planning on selling her for a fp red and buying a meth kit, and see what she puts down.
Old Mar 24, 2009 | 10:33 PM
RoadSpike's Avatar
surprised you haven't joined the e85 crowd honestly its supposedly more prolific in socal.
Old Mar 24, 2009 | 10:37 PM
Appauldd's Avatar
In looking at your log....you have a lot of room to tune for more power. The negative timing and rich "10" AFRs at the top of spool can be fixed up quite a bit.
Old Mar 24, 2009 | 10:39 PM
RoadSpike's Avatar
Yeah I'm hoping I can eek quite a bit more out of it. Really whats interesting here is that its much faster despite the lack of tuning and as your pointed out rich AFR's and low timing.
I do expect timing to be a little lower than you guys are used to due to the 91 octane when all is said and done.
Old Mar 24, 2009 | 10:44 PM
Appauldd's Avatar
Your spool on it looks great.
I was super impressed when I put on my green. It made more power without a tune.....just like you and your red. Now with my revolver cams and ported head.....holy crap....400hp is so easy on pump 93.
Old Mar 24, 2009 | 10:50 PM
RoadSpike's Avatar
Thanks I tweak with this tune some more and post up a log in a couple days. I don't know how much timing i can get out of it but we will see. 91 octane is pretty horrible stufff lol
Old Mar 24, 2009 | 10:52 PM
spdracr's Avatar
haha i was laughing no offense just because i prefer adding timing as opposed to boost on my VIII turbo and my car likes timing much more. 8* peak timing on 23 psi im at 15-16* peak timing at 18.5psi at redline. on same **** gas you have. and with absolutely no knock wat so ever. just spend some more time tuning that beast. im sure you'll get it fast as hell soon enough or just run some meth or join E85 crew im still debating since i picked up a IX turbo today haha
Old Mar 24, 2009 | 11:36 PM
RoadSpike's Avatar
I hope you don't consider this log a finished product I just got the turbo in a couple days ago. Tuning is pretty much non existent on this run.
I'm not sure how you could have run 8 degrees timing at peak torque anything higher than 3-5 degrees here and it would knock up a storm on the stock turbo. I was running similiar boost to you during those times as well.
As far as the decision to run more boost well its simple and in 2 parts. First this turbo's efficiency range is higher up than the stocker so to get the most out of the turbo I'll need to turn the boost up. Secondly now that I have a much larger FMIC its safer to run up the higher boost levels, all in all I should get a better VE on the motor by running it this way.
Old Mar 25, 2009 | 06:49 AM
rolly1818's Avatar
Registered User
lean out slighlty and push timing and you will have a ball!!!!!
damn i hate you.
Old Mar 25, 2009 | 09:38 AM
fostytou's Avatar
EvoM Community Team
Quit tempting me dammit!
Old Mar 25, 2009 | 09:44 AM
RoadSpike's Avatar
Leaning out the tune and upping the timing today I'll probably have a log by lunch time and maybe an even better one after work.
One of the things i like about this turbo i wasn't expecting is the turbo actually has that low turbo whistle noise when starting to spool up. It makes the car sound even meaner now lol!
Old Mar 25, 2009 | 09:52 AM
jcsbanks's Avatar
The only Red I've tuned has failed. Warranty inspection awaited. Lots of people reporting FP Green and now Red failures in the UK, not clear why it is happening, there are not the same number of stories about stock turbos and GT3x tuned by the same people in the same way. I thought it wouldn't happen especially since I didn't push it hard.
I liked how it drove except for the surge before 4000 RPM in high gears, which stopped me getting one for my own engine.
