how to run a ics button on a 05
Old May 28, 2009 | 07:11 AM
97talon420a's Avatar
ok i have/had (it was totaled)a 03 running e85 with the ics button as the switch from pump to e85.
i'm going to pick up a 05 on Saturday and i want to take my 03 center console and use it in the 05 so i do not have to run a toggle switch. My question is has any body done this? If where do i run the pins in to the 05 ecu?
Old May 28, 2009 | 07:29 AM
l2r99gst's Avatar
I've never seen the 03/ICS switch wiring, but for the 05 ECU, all you need to do is send a 5V source to pin 42. All I did was use a simple push button switch...one end hooked to 5V source, the other end hooked to pin 42.
Old May 28, 2009 | 07:36 AM
SEEnoEVO's Avatar
^this
or you can order the harness with switch, wires, and LED from Jamie.
http://www.dsm-ezine.com/evoVIII_adc_switch.html
Old May 28, 2009 | 07:50 AM
travman's Avatar
As posted just run the jackofrades switch - much easier and you can mount it in your glove box out of site.
Old May 28, 2009 | 07:53 AM
what/where did you get a 5Vsource from?
Old May 28, 2009 | 08:03 AM
l2r99gst's Avatar
I have a device from Innovate called and SSi4 that I used that has a 5V out. But, the ECU has a 5V output as well on pin 81. I think someone else used this for his 5V source. I forgot his name, but you may be able to find it via a search. I can't comment on that method, since I didn't use it.
Old May 28, 2009 | 08:08 AM
SEEnoEVO's Avatar
If you look at the wiring diagrahm on the link above, it shows where to get the 5V source from.
Old May 28, 2009 | 08:11 AM
travman's Avatar
Where it says 12v ignition?
You want a 12v ignition source if possible so you don't lose alt maps while cranking - e85 requires the use of alt ipw start-up table for best back and forth map switching. If you don't get a good 12v ignition source under cranking you will lose the alt. maps and divert to the main maps for the # of seconds it takes to go back to the alt. maps after the car fires.
I got a turbo timer harness and just took the 12v source from it so I dont lose the map switch under cranking - works great.
Old May 28, 2009 | 08:16 AM
if you look at this link http://roadraceengineering.com/evo/t...-ecuwiring.htm pin 81 is the 5V out put but pin 44 is the isc not pin 42 nothing is in 42.
Old May 28, 2009 | 08:25 AM
SEEnoEVO's Avatar
42 is the pin that once it sees power, activates the switch over to the alternate map. There is no pin in the harness, but there is one in the ECU.
Old May 28, 2009 | 08:40 AM
l2r99gst's Avatar
You add a pin connector to pin 42 on the ECU plug. Pin 42 is the one used for manual map switching.
Of course, depending on what ROM you use for your 05, you can simply use tephra's latest 96530006 with the tps switching and not have to worry about wiring in a switch.
Old May 28, 2009 | 08:53 AM
Why would i do tps switching when I'm running either e85 OR 93 i need two different maps depending on what I'm running. They both have different injector scaling.
Old May 28, 2009 | 08:55 AM
SEEnoEVO's Avatar
The TPS is used for the map switching. I think you are misunderstanding things. You can either do a manual switch, or tephra now has where you can switch maps by utilizing the TPS in a certain way.
Old May 28, 2009 | 08:57 AM
o i under stand thanks for clearing that up for me. i might have to look in to doing that insted that would be a lot easier. does any body have a link on how to set this up?
Old May 28, 2009 | 05:41 PM
tephra's Avatar
V7 is *almost* out, includes TPS map switching.
If you feel like READING a LOT :P look at the V6 testing thread
PalmTreeZ
Apr 9, 2017 12:44 PM
evodude32
Apr 9, 2016 12:01 AM
pkron05
For Sale - Cars For Sale
11
Dec 25, 2015 05:44 PM
sublime44
Nov 1, 2010 05:56 AM
kstpeter33
Jun 10, 2008 04:57 PM
