Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Feb 9, 2016 | 06:10 PM
  #421
kaj's Avatar
kaj
Originally Posted by hearnoevo
And the results were? If you can post the sheet results that would be great
I should know in the morning. I couldn't get any time off of work, and every time I went by the smog shop it was closed.
Old Feb 10, 2016 | 09:58 AM
  #422
hearnoevo's Avatar
ecu
Is there a reason why you are trying to get all seven settings to show ready instead of just the ones that are supported by our cars?
Old Feb 10, 2016 | 11:37 AM
  #423
kaj's Avatar
kaj
No, I'm just trying to get it to pass. The settings I've tried give me three or seven. I can't find a combination that gives me just the correct ones.
Today I found the ECU is showing the EGR "not supported".
Old Feb 10, 2016 | 11:44 AM
  #424
RazorLab's Avatar
Just as an FYI, settings on post #361: https://www.evolutionm.net/forums/ec...l#post11436542
Passed just the other day in California.
Old Feb 10, 2016 | 01:30 PM
  #425
kaj's Avatar
kaj
I think my problem is too many conflicting settings.
Old Feb 10, 2016 | 01:33 PM
  #426
RazorLab's Avatar
If the tables are the same address's it doesn't matter
Old Feb 10, 2016 | 02:11 PM
  #427
kaj's Avatar
kaj
when i change the upper set to what some people have posted here, some of the bottom ones change and vise versa.
and when they change, a couple of the hex codes change to ones that aren't even shown on any of the tables. it's f'ed up.
i've decided to put car back to stock and smog legit. i have all the sensors hooked up and the cat on the car anyway, so i don't even NEED to force pass anything. all i have to do is swap injectors and map sensor.
i only did it this way because it was supposed to be easier LOL.
Old Feb 10, 2016 | 02:18 PM
  #428
RazorLab's Avatar
Right, they change when you change the other because the addresses are the same.
Wait, you aren't passing those OBD2 tests because of your injectors and map sensor?
Those should not affect them at all. Which map sensor? Are you turning your EGR off or something?
Old Feb 10, 2016 | 03:02 PM
  #429
kaj's Avatar
kaj
update:
it turns out my EGR was turned off @ bit 9. fixed. but now i have a p0403. it never ends LOL
my map and injectors were keeping me from putting in a stock ROM to pass smog. i figured i could make some changes to pass my current tune and be done. i was sorely mistaken.
but.. at least now the smog shop is seeing the EGR, that's a start. now i just gotta figure out why i have a code. everything is hooked up. i'm reading lot of people that replace the entire evap system and still get the p0403. it does not look promising LOL
Old Feb 10, 2016 | 03:08 PM
  #430
RazorLab's Avatar
which Map sensor? You sure you have all the proper EGR offsets and pressure diff changes done?
Do you have the EGR test disable via Periph 2?
Old Feb 10, 2016 | 06:09 PM
  #431
kaj's Avatar
kaj
passed. jesus.
turns out my EGR was turned off in periphery bit 9, so i fixed that. i then had a p0403 code, so then changed bit 15. finally passed. what a pain in the ***.
and why do i have so many availability and completion patches? i have no idea. here is my setting that passed today. i also have all sensors hooked up (i never remove them) with an OMNI map sensor and grimspeed boost solenoid.
Old Feb 10, 2016 | 10:40 PM
  #432
3gturbo's Avatar
You left all the tests to on and passed Guess you missed the multiple posts saying not to do that
Old Feb 10, 2016 | 10:45 PM
  #433
RazorLab's Avatar
I literally told you two times above but you chose to ignore me, among the other tips I posted. That's okay, I have now learned for the future not to try and help you with tech related questions.
Good luck with every thing!
Old Feb 11, 2016 | 10:08 AM
  #434
kaj's Avatar
kaj
To be honest, I don't understand the questions. I'm not very good at the more in-depth ecuflash stuff. I was busy and stressed, trying to get the car to pass, so I wasn't able to take the time to look into what you were saying. My apologies. The only part that made sense was "are you turning the EGR off?". That's what chucked for me, so thank you.
Old Feb 11, 2016 | 10:11 AM
  #435
kaj's Avatar
kaj
I honestly had no idea what I was doing, since my ROM didn't look like any of the others posted, for the most part. I was grasping at straws, trying to make SOMETHING work. It finally did, so that's a plus.
I set my top set of availability/completion settings to what people here used...didn't work.
So then I set the bottom ones to what people here used. Didn't work. My tuner sent me the ROM all his guys use. Didn't work. So, I was pretty much on my own.
