Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9
Old Feb 24, 2011 | 12:36 AM
  #151
RoadSpike's Avatar
Originally Posted by tscompusa
ya i just checked and seen it thanks. my bad. mrfred answered a guy a few posts up.
how comes it just works on the 9653? is it because the 9653 came out of a car with no map sensor?
Becuase the 9563 came with no map sensor there are no tests the ECU does for it so essentially we are just logging voltage on the sensor which the ecu was kindly already setup for.
Old Mar 12, 2011 | 07:00 PM
  #152
Ralph's Avatar
Nevermind! Figured it out ;D
Old Mar 14, 2011 | 08:35 AM
  #153
EvoPower81's Avatar
I am using 9563 on my JDM Evo7 and I get a consistent CEL light now I installed the OMNI 4-bar. Doesnt anyone know why?
Old Mar 14, 2011 | 11:20 AM
  #154
And's Avatar
And
whats the code?
Old Mar 14, 2011 | 11:49 AM
  #155
EvoPower81's Avatar
Originally Posted by And
whats the code?
HAS PLENTY CODES which dont make sense
Old Mar 14, 2011 | 12:12 PM
  #156
And's Avatar
And
you'll probably find its evoscan not reading the codes properly, I'd suggest you try a different OBD code reader or join pins 1 and 4 on the port and see what the codes are then,
Andy
Old Mar 17, 2011 | 03:14 PM
  #157
burgers22's Avatar
Check the EGR pressure diff is set to 0, then clear the codes.
Old Mar 27, 2011 | 03:03 PM
  #158
blacktab420's Avatar
When I replaced my oem map sensor with the omni one yesterday, I carefully hold the sensor because i red here that it is spring loaded and that it would fly away . However , there was no spring at all at my surprise.
I have a supposely stock IX MR, is it normal ?
Old Mar 27, 2011 | 03:52 PM
  #159
RoadSpike's Avatar
That's normal AFAIK the MDP sensor should not come with a spring underneath it just a o-ring seal.
Old Mar 27, 2011 | 07:06 PM
  #160
All right, thanks !
Old Apr 30, 2011 | 07:09 PM
  #161
motocooney's Avatar
Just out of curiousity, what would happen if you made these changes to your rom but with the stock MAP sensor?
I feel really stupid but I switched to V7 about 6 months ago and started with the Phenum V7 that already had the mods for the Omni 4 bar.
I'm about to order a 4 bar and I was just looking at the MAP settings in my Rom and noticed that it's already set up. Ooops!!
Obviously, I've been running like this for 6 months with no issues.
Old Apr 30, 2011 | 07:38 PM
  #162
tscompusa2's Avatar
you'll probably notice better throttle response now lol.
Old Apr 30, 2011 | 08:03 PM
  #163
motocooney's Avatar
Do you mean running a stock MAP sensor with 4 bar MAP settings will yield better throttle response or that when I install the 4 bar, I will get better throttle response? Because I honestly never noticed anything weird running like this
Old Apr 30, 2011 | 08:07 PM
  #164
BluEVOIX's Avatar
I did the opposite and ran a Omni 4 bar map with oem settings and the car would not hold idle for more than a couple seconds. I would have to modulate the throttle too keep it from dying when in neutral.
Old Apr 30, 2011 | 08:16 PM
  #165
motocooney's Avatar
Hmmm...that's kind of weird then. I would have never known the difference had I not been checking out the MAP settings. Are you using a MBC? would it matter? I use a MBC.
Is there any benefit in using a 4 bar MAP sensor other than being able to log boost if you use a MBC?
TScomp mentioned throttle response....like there is an improvement in performance to be had from switching to a 4 bar map.
Not saying there isn't, just wondering.
