TephraMod V7
Old Feb 14, 2011 | 07:01 PM
  #2191
C6C6CH3vo's Avatar
I cant change the value in Hz column. Any change results in a "0", need to scale it beyond 1610 hz
Old Feb 16, 2011 | 06:46 AM
  #2192
C6C6CH3vo's Avatar
^help^
Also, I found just a few type errors, I can make a list if needed for future v's. Here's one: "Vehicle speed must be UNDER (OVER) this value to allow NLTS to be activated:"
Old Feb 17, 2011 | 04:49 AM
  #2193
bleunetizen's Avatar
Wow very long thread.. is 8857008 out yet?
Old Feb 18, 2011 | 05:37 AM
  #2194
todd6027's Avatar
Originally Posted by ecktt
anyone testing the 90550001 v7?
Hows progress going?
X2 Any news
Old Feb 19, 2011 | 08:09 PM
  #2195
PeteyTurbo@KHC's Avatar
Has anyone had sucess with 94170715 in regards to psi based boost control function, specifically error correction? I decided to give it a shot after using 96530706 and the eroor correction pulls duty cycle even when I request 40psi PLUS atmospheric pressure either in the adder or not, it makes no difference..Also it seems there some other variances between this rom and 965 that will cause starting difficulties for some, specifically in the priming and cranking enrichment values. Anyone have any ideas or am I just retarded again? All of the associated scalings show omni4bar so I am not sure what to think with this one unless boost adder psi is actually kpa or something.
Old Feb 21, 2011 | 04:05 AM
  #2196
Icem@n's Avatar
Originally Posted by todd6027
X2 Any news
Anything yet?
Old Feb 21, 2011 | 08:00 AM
  #2197
I also noticed the target boost tables go above 24.6 in the 94170715 rom.. Has anyone been able to sucessfully run ecu boost with this rom?
Old Feb 21, 2011 | 08:03 AM
  #2198
tephra's Avatar
You can change the scaling and nop out the SHLR in the code to get more boost
I can't remember exactly because its been a while - but maybe post in the mrfred direct boost thread
Old Feb 24, 2011 | 06:10 PM
  #2199
W2J's Avatar
W2J
Anything yet?
bumppppppp!!!
Old Mar 7, 2011 | 05:00 AM
  #2200
audiofan's Avatar
id 97470001, anybody has this patched??
or wich one could I use (evo 8 EDM)
Old Mar 16, 2011 | 12:02 PM
  #2201
raasfaas's Avatar
Originally Posted by raasfaas
Okay maybe I'm overlooking something, but I'm having a bit of trouble logging lb/min in evoscan. When I originally downloaded V7 I was able to log it with no problem.
That was a while back, now I tried today and got some weird readings (its stuck at 204.4692) So I figured maybe I changed around one of the MUT addresses so I copied the entire MUT table from the factory V7 rom, and removed and reinstalled a fresh copy of evoscan 2.6 and copied in the data to the XML (so basically it's like I downloaded everything from scratch)
I honestly can't remember but was there anything else that had to be done to be able to log lb/min?
bumping this for some feedback...anyone else having problems logging lb/min?
Old Mar 16, 2011 | 12:29 PM
  #2202
Boosted Tuning's Avatar
Yes, I have successfully ran ECU boost with full error correction on the 9417 V7 ROM.
Old Mar 18, 2011 | 05:48 PM
  #2203
3gEclipseTurbo's Avatar
Big shout out to tephra, just passed emissions with no cat, no o2 sensors(full time open loop), no egr, and everything else emission related. Thanks
Old Mar 20, 2011 | 07:04 PM
  #2204
Ralph's Avatar
Values they are set to..This is what I have for tps axis:
10139.2
25660.8
10139.2
25660.8
Also this car is not reacting well to this rom but I am going to clean out my xml's and try a fresh one.
Flash car> car will not start(cranks)>flash back tune before applying 0-100 tps scaling>then flash tune that prevents car from starting>car fires right up>wait 10 min and start again=car will not start lol....I also believe I had the map sensor scaling set for jdm 3 bar for the target boost table but I doubt it would prevent the car from starting.. Probably something in the xml or wgdc TPS but I will post up what I find to be the problem.
Did you ever find out what was causing this problem? I have that same y-axis values messed up problem. My car also will not start after I flash the car, run it.. and turn it off for a minute. I'm using the OMNI 4Bar with omni settings in place.
Old Mar 20, 2011 | 07:12 PM
  #2205
Raptord's Avatar
This is what your table def. should look like for max upward tps correction:
