TephraMod V7
Old Jun 10, 2011 | 04:30 PM
  #2356
tscompusa2's Avatar
Tephra the 88580714-TephraMod-V7 has errors right off the download link. see pictures below:
The file it inherits has the errors though 88580014
then when i look at that xml it inherits 88580013
so whatever code is causing the errors is in 88580013
Old Jun 10, 2011 | 07:41 PM
  #2357
tephra's Avatar
because you have a "/>" in the line above it - you do NOT need the "</table>" on that line
delete it
Old Jun 10, 2011 | 08:02 PM
  #2358
tscompusa2's Avatar
delete it
that did the trick. thank you!
Old Jun 20, 2011 | 12:38 PM
  #2359
Tony.O's Avatar
now i have on the ECU 94170715 can i change it to 96532607 ?
Old Jun 20, 2011 | 03:46 PM
  #2360
project_skyline's Avatar
Does anyone have the evoscan data line for logging baro+air temp compensated 2byte load?
Old Jun 22, 2011 | 03:28 AM
  #2361
tephra's Avatar
its like +4 or +6 from the raw load...
Old Jun 22, 2011 | 10:55 PM
  #2362
So add 4 or 6 to the raw load?
Old Jun 26, 2011 | 06:11 AM
  #2363
limbi's Avatar
can i use the USDM on an AUSDM evo 9?
Old Jun 26, 2011 | 06:12 AM
  #2364
tephra's Avatar
why would you want to?
Old Jun 27, 2011 | 12:41 AM
  #2365
Benja's Avatar
Lol...
Old Jun 27, 2011 | 03:41 AM
  #2366
HyperDisorder's Avatar
I've tried a few things trying to get NLTS for 96260709 working. Hooked up to pin 88 as my guess for the right clutch switch pin, but no luck.
I've come across the memory locations for the clutch switch in v2 of this mod for other ROMs. So this is probably a question for Tephra, but if anyone knows the memory location for the clutch switch that the mod is looking at, I love to know it. Then I'll work out which pin enables any bits in that memory location.
Alternatively, I do have the memory location for pin 88 - both bits 2 & 3 on FFFF8895 are enabled when I ground the pin.
Any help would be appreciated, thanks.
Old Jun 28, 2011 | 07:09 AM
  #2367
limbi's Avatar
ok does anyone have an AUDM evo9 map?
Old Jun 28, 2011 | 07:16 AM
  #2368
tephra's Avatar
88580714 is AUDM/Evo9
Old Jun 28, 2011 | 07:18 AM
  #2369
tephra's Avatar
96260009 - clutch flags = 0xFFFF88CA, bit #1 (second last bit on the right from memory)
Old Jun 28, 2011 | 12:24 PM
  #2370
Awesome, thank you. I suddenly have new plans once I get home from work tonight haha
