TephraMod V7
Old Jul 28, 2011 | 07:21 AM
  #2416
dparrish's Avatar
I found that the stationary rev limit didn't work with my car on 96530706 without a code patch. I think ziad perhaps had posted the patch on another thread. I *thought* that was for the 3-plug ECUs though I could be wrong.
Old Aug 10, 2011 | 03:58 AM
  #2417
d1kid's Avatar
donation sent for 96260009
Thanks
Taylor OBrien
Old Aug 10, 2011 | 05:37 AM
  #2418
Evoloved's Avatar
I think this ECU program is awesome
Old Aug 15, 2011 | 01:25 AM
  #2419
Ian0611's Avatar
I'm trying to switch over to using Ecuflash 1.43.3150 so that I can do standalone data logging but I'm having some trouble with it reading the V7 version of 94170715. Whenever I open a ROM and try to scroll down the list of tables I get an error message once it gets to here:
<table name="== EDIT THE TABLES BELOW FOR LOAD OR PSI BOOST TARGETING ==" category="Global Boost Control
'TYPE' (Choose LOAD or PSI Targeted Boost Control)" address="0" type="1D"/>
All of the tables above this show and work fine. As soon as I scroll down to these tables it never makes it past this line and then it gives me an error message and ECuflash closes out. Anybody else have trouble with this and know how to fix it? FWIW- The same ROMs work fine with Ecuflash 1.42.
Old Aug 15, 2011 | 01:28 AM
  #2420
And's Avatar
And
remove the address="0" from the line and is should work
Old Aug 15, 2011 | 01:31 AM
  #2421
Ian0611's Avatar
Wow! Awesomeness!!! I knew it had to be something simple. Thanks a lot man!
Old Aug 15, 2011 | 03:12 PM
  #2422
rolly1818's Avatar
Registered User
anything out yet for 8857?
Old Aug 15, 2011 | 03:19 PM
  #2423
evo6panama's Avatar
I'm using the 96530706 in an evo 5 with evo 8 ecu, all swapped with no problems, in the begining the launch controller wasn't working and I figured it was because of the clutch switch, I've installed a clutch switch from an evo and now it works but the NLTS wont work... Anyone have clue?
Old Aug 16, 2011 | 06:38 AM
  #2424
catman78's Avatar
Where can I find the most up to date definitions for:
evo7base_20081101.xml
96530006.xml
TephraMOD-96530706-v7.xml
I'm using Version 1.42.2595
thanks
Old Aug 16, 2011 | 04:22 PM
  #2425
dparrish's Avatar
http://code.google.com/p/ecurom/sour...tsubishi%2Fevo
Old Aug 17, 2011 | 08:36 AM
  #2426
evoscan's Avatar
Silver Sponsor
www.evoscan.com/roms/mitsubishi
Old Aug 17, 2011 | 11:41 AM
  #2427
nonschlont's Avatar
donation sent.
Old Aug 20, 2011 | 01:02 AM
  #2428
kaj's Avatar
kaj
so many pages.. would anyone happen to remember who it is that sells the cables that connect to the serial out from our widebands, and is built nice and neat into a serial port? i bought one from a member here for about $12.. but i can't remember who. i already have my serial > usb cable.. i'm just missing this ONE piece. anyone?
Old Aug 20, 2011 | 01:41 AM
  #2429
Mellon Racing's Avatar
if you're referring to the AEM Uego data logging cable this is what you need http://www.mellonracing.com/index.ph...roducts_id=467
Old Aug 20, 2011 | 01:50 AM
  #2430
kaj's Avatar
kaj
a bit pricey, but when in a bind.. assuming that works with any serial-out wideband? i have the Innovative controller/gauge that i'm installing soon. sorry if off topic, i can take it to PMs. but i'm thinking other people will be looking for the same stuff while tuning/logging V7.
