TephraMod V7
Old Jul 11, 2013 | 01:32 PM
  #2926
ecktt's Avatar
Originally Posted by georg1970
Hi everyone,
I need some help. The definition file for my JDM Evo7 ROM (98640014) is very poor resulting in incorrect readings when trying to make a log with 23 Psi boost. I have found here that my ROM can be substituted with 90550001 without any problem. Moreover, i read that there is Tephra version for that ROM which I would like to get (buy). Can anyone tell how can i get it?
Thanks
Shota
Make a reasonable donation
Secondly if you would like to donate just PAYPAL whatever you can/want to donations@globalshare.net
Old Jul 12, 2013 | 03:11 AM
  #2927
georg1970's Avatar
Got it, thanks.
Old Jul 20, 2013 | 01:47 AM
  #2928
jameswwt's Avatar
Hi Guys,
im helping a friend to try obtaining the correct Tephra & XML features for his JDM Evo 8 stock ecu to convert to SD.
Really hope someone could help by sharing the ROM with TephraV7 & the correct XML with Immobilizer disable for his Jdm Evo 8 stock ecu.
Will give a donation.
Thank you.
Old Jul 21, 2013 | 04:03 AM
  #2929
Benja's Avatar
Just flip the Periphery for immobiliser disable.
Old Jul 21, 2013 | 06:36 AM
  #2930
jameswwt's Avatar
Thanks Benja & do you have the TephraV7 Rom for Jdm Evo 8 with SD?
Old Jul 22, 2013 | 11:15 AM
  #2931
jameswwt's Avatar
Hi Anyone kind to help?
Thanks
Old Jul 23, 2013 | 01:56 AM
  #2932
07EvoIX's Avatar
what's wrong with the ROM on page 1?
EDM/JDM/USDM 96530006 (Tested on all years of EDM/JDM/USDM EVO8's)
Option 3 is SD
cheers
Old Jul 29, 2013 | 05:29 AM
  #2933
SS1000RR's Avatar
Nlts isn't working on my ix, What exactly has to be done with the clutch switch?
Old Jul 31, 2013 | 05:09 AM
  #2934
SS1000RR's Avatar
Nevermind I got it, the load has to be set Over not Under. Sweetness
Old Aug 2, 2013 | 05:27 AM
  #2935
coltcztowner's Avatar
88580714 to 88590715
Good day
I have a major question to do
Is there any posibility to place to my ECU tha allready has the 88580714 rom which is place in a EVO 9 European specs the 88590715 rom.
I want to do that cause there are more tables in it.
Is there anyone that has done it this before or know how to do it...
It will be very helpfull...
PS:when i tried to do the replacement the car wont starts at all.
Thanks Mates
Old Aug 3, 2013 | 03:30 AM
  #2936
07EvoIX's Avatar
you will need to change the immobilzer code or turn it off completely for the car to start.
as for the pins and sensors I wouldn't know.
cheers
Old Aug 5, 2013 | 06:17 AM
  #2937
mprizolakis's Avatar
cheers
Good day
This is a very hellpfull answer.
But...
I have allready done this to my car (turned off the immobilizer) and with the new rom (88590715) still doesnt starts to me (i have european spec evo 9 too ).
Here is what i want
I have placed bigger injectors and i want to get accees to the syncload menu or acceleration enrichment (or so what something like that) in order to correct fuelling during pressing full throtle. with the 88580714 rom that i have installed too when pressing full throtle the car goes heavilly reach and then it corrects it self...i need to get access to that tables that corrects fuelling but i dont know how to do something like that...i saw that 88590715 rom does that but this rom doesnt works to my car...iam a litle bit confused.
Any sugestion tips or tricks will be a major help
Cheers
Old Aug 5, 2013 | 06:49 AM
  #2938
211Ratsbud's Avatar
Your problem is 99% nothing with those tables. I use 8858 on my usdm car that was originally 8859. I'm on 1000cc injectors. How's your fuel trims and boost leak test?
https://www.evolutionm.net/forums/ec...8586714-a.html
Old Aug 5, 2013 | 10:21 AM
  #2939
Thanks a lot my friend
I will give it a try and i will inform you what is happening
once again thanks a lot !!!
Old Aug 5, 2013 | 05:32 PM
  #2940
EvocentriK's Avatar
Thanks
Grab 96534706 if you want the 3D VE table version.
