TephraMod V7
Old Aug 5, 2024 | 07:23 AM
  #3661
wizzo 8's Avatar
It looks like all the hyper links in the first post are dead. I have a Tephra mod tune and I'm unable to open it. I'm guessing I need to load the latest Tephra downloads but I'm not sure.
Old May 6, 2025 | 12:34 AM
  #3662
BigBlackDeck's Avatar
Can this patch NA Lancer ecu
My rom # is 54740002, I would like to add a stationary rev limit but its not working, not sure if my ecu need to be patch first? hope anyone can help me or configure my rom thanks
File Type: zip
Old Jul 16, 2025 | 01:53 AM
  #3663
TrustedManiac79's Avatar
I can't find the fan control tables
I'm running a 3g eclipse ECU in my 98 Eclipse Spyder gst using 96530706- TephraMod-phenem v7, yes I did put the xml in the Evo rom metadata in ECU flash. But I cannot find the tables for the fan control at different temps anywhere in this rom at all. I have previously used ECU flash with ceddymods, so I'm familiar with most of the concepts & layout. I haven't started the vehicle yet on this ECU, trying to get things similar to how I had it with dsm ECU & ceddy's rom before proceeding. I know that there's a issue with the fact it's pwm for fan control but I also read you can get it to work full speed at certain temps & was wanting to try it. If someone could please inform me of why it's not in the room or what I'm not doin correctly is b very appropriative
Old Jul 16, 2025 | 07:17 AM
  #3664
black_out's Avatar
If you search the forum for 9653 fan control you’ll find the addresses to add it. Unfortunately with the 3g ecu you can’t just set the fan PWM to 100% like the Evo ecu to get the fans working the same way. Found this out the hard way. I started using the 3g ecus in my 1gs/swapped cars with fan controllers in the thermostat housings. I run evo 8 ecus in my 2gs instead since they can have the fans set to 100% PWM and work
Old Sep 14, 2025 | 06:57 AM
  #3665
Moriaan1990's Avatar
hey,
so i guess nobody is here to help me add this nice functions to my europe outlander XML to enjoy???? 7280011/7280009
best regards
Old Sep 18, 2025 | 02:28 AM
  #3666
KK0ng's Avatar
Originally Posted by Moriaan1990
hey,
best regards
post your map here, and i will have a look
Old Sep 18, 2025 | 09:38 AM
  #3667
ViciousLSD's Avatar
Can you please look into mine (evo9)? Ever since I went SD my idle and decel (with or without AC) has been getting worse (new MAP, sensors, coils) My latest tuner gave up on the Tephrav7 and used an older single map definition file. Power is great I guess but idle is all over and dies eventually while idling(cool down). One good thing about this file is it has the older definitions with a bunch more idle related but i'm not sure where to start. Do you have some links/info I can look into? I do want to get back to Tephrav7 but I was giving this enough chance for the politics of changing tuners/builder around here. I worked with 5 already. TIA
Old Sep 18, 2025 | 09:42 AM
  #3668
KK0ng's Avatar
sure you can attach it here or send it to okane[at]telenet.be
Old Sep 18, 2025 | 09:55 AM
  #3669
ViciousLSD's Avatar
Thanks. Give me some time. I will send 2 files, before and after version of the tuner's attempt to make AC off-throttle a bit better and slightly better chance of not dying. but now it could idle at 2-3k
Old Sep 25, 2025 | 05:45 PM
  #3670
ViciousLSD's Avatar
Ola. I sent it to this addy. thanks
Old Nov 7, 2025 | 01:38 PM
  #3671
Jhero23's Avatar
Can you also help me out I'm getting knocksum.on V7.?
Old Nov 12, 2025 | 09:46 AM
  #3672
Jhero23's Avatar
Big props to @KK0ng for getting the timing sorted out on my original "Big Al" tune. I can now do a WOT pull without a single knock
Old Apr 20, 2026 | 01:21 PM
  #3673
Jhero23's Avatar
Need XML for V7+Mods 88590715
Does anyone have a copy of the lupdated XML.
Originally Posted by phenem
I just updated the second post with the correct XML and correct ROM with the appropriate mods and speed density patches. Please delete and re-download and replace what you have (at least the XML so we are all running the same)
TephraMod V7 USDM Evo IXOption 1 88590715 (v7) - Download Option 2 - Thanks to recompile 88590715 (v7 + Mods) - Download | MirrorSetup for JDM MAP and PSI based boost control (mrfred)WGDC Correction Interval set to 1 (Stock = 10)Max Total Upward WGDC Correction @ 100% TPS set to 0 (Stock = 10)EGR System Disabled (mrfred)Max Timing Retard set to -20 degrees (tephra)FAA bit.10 disabled ("weird unknown" timing pull at cruise)FAA bit.09 disabled (cat-warmup ignition retard)FBA bit.00 disabled (lean spool)FCA bit.09 disabled (EGR Test)OBD Inspection set to Pass all tests (acamus)Rear O2 Heater patch applied (mrfred)Fuel Cut Load Limit x2 and set to 300 (mrfred)
The one I have is not the updated one
Old Apr 21, 2026 | 07:21 AM
  #3674
KK0ng's Avatar
it's on address 7284
Old Apr 22, 2026 | 11:03 AM
  #3675
Jhero23's Avatar
Thank you.
tephra
Sep 13, 2021 01:07 AM
tephra
Aug 19, 2016 10:07 AM
Appauldd
Apr 13, 2011 01:37 PM
l2r99gst
Mar 26, 2010 07:32 AM
