TephraMod V7
Old Jan 8, 2010 | 11:10 PM
  #1321
esevo's Avatar
Originally Posted by travman
just copy the SD table data into your V7 xml from mrfreds SD patch thread and copy in the settings from his pre-patched rom. No need to wait?
if you need help with that pm me, i have every thing setup in my own V7 rom / xml
I did this and changed everything over from my other maps ect. SD and MAP was showing when editing the maps, I then saved it and closed the bin. I open the bin again and the SD and MAP sections are gone??? Yet in the XML's it shows them there.
Evan Smith
Old Jan 10, 2010 | 12:02 PM
  #1322
phenem's Avatar
I updated my post on the first page (link here) and updated the XML in the ZIP files, please re-download and use the new XML files, ROM files have not been changed at all.
Old Jan 10, 2010 | 02:53 PM
  #1323
StreetEvo's Avatar
Phenem, do you have any idea why the nlts Rpm drop value isn't changeable in the 96532706 rom?
Old Jan 10, 2010 | 03:26 PM
  #1324
phenem's Avatar
I fixed it, download my version again and use the supplied XML.
Old Jan 10, 2010 | 03:40 PM
  #1325
StreetEvo's Avatar
ok thanks
Old Jan 10, 2010 | 03:57 PM
  #1326
Appauldd's Avatar
Phenem.....Did you fix the issues with the MAT tables ? ? ? They show up all scrambled.
Old Jan 10, 2010 | 04:16 PM
  #1327
Tonba's Avatar
WTF??!
The tables are all scrambled... both the X & Y axies...
Old Jan 10, 2010 | 06:08 PM
  #1328
phenem's Avatar
You will still need to apply the MAT patch if you only want to use MAT, if you want to GM IAT for SD then you need to apply the correct SD settings.
Read this post by 03whitegsr: https://www.evolutionm.net/forums/ec...nsity-mat.html
Old Jan 10, 2010 | 06:16 PM
  #1329
Appauldd's Avatar
I am talking about the NON SD v7. I have the MAT stuff showing up as scrambled. I am curious as to if this could be causing issues, especially with cold startup and drivability.
Could it be that the values are screwy because I am not running MAT?
I want to run it with the NON SD v7 so I can log temps. Any suggestions??
Oh and the MAT patch thread is HUGE.
Old Jan 10, 2010 | 06:19 PM
  #1330
phenem's Avatar
That is not a link to the MAT patch thread it is a one page explanation of what the MAT patch is vs. the SD MAT. Read it, I think it will help you understand.
You will have scrambled values because you didn't apply the MAT patch. This should have no effect on cold startup or drivability, it is because you are not running MAT, it is simply there to make it easier to apply the patch if you want to run it.
Old Jan 10, 2010 | 06:22 PM
  #1331
R/TErnie's Avatar
Thanks Phenem, I'll be sure to update! you guys rock
Old Jan 10, 2010 | 07:26 PM
  #1332
Appauldd's Avatar
Yup. Thanks ! !
Old Jan 11, 2010 | 04:10 AM
  #1333
And's Avatar
And
is it possible to stop the CEL light flashing when you turn on the ignition when in the valet mode? I know you can change the time it flashes for after you turn it off.
The reason I ask is because if some one uses the car etc having a flashing CEL alerts them that they is something wrong or a valet mode active, if this didn't flash when enabled they'd probably think something else is wrong?
Cheers
Andy
Old Jan 13, 2010 | 01:45 PM
  #1334
CWiLL's Avatar
Thanks thepra and all the guys involved in the Stock ECU development, you guys work really hard on this stuff. I've been hearing a lot of good things about tuning on the BIG MAPS w/ V7, can't wait to try it out, I'll share some results when I get them.
Old Jan 13, 2010 | 02:14 PM
  #1335
aka.ralliart15's Avatar
I have a test car we could use
I actually want to try out the NLTS feature but I'm scared of something going wrong, how much boost can the NLTS feature hold in between shifts? Anybody know?
