launch maps
Old Aug 6, 2012 | 09:47 PM
  #196
kronik5383's Avatar
Originally Posted by jhoganusaf
So this has probably been asked a few times, but I only see 3 psi with the 2 step. I'm using a td06 20g turbo. Stock ecu and used ecuflash without tephra mod to enable launch control. It's set to 5k rpm. What boost should I be seeing and how can I correct this?
use negative timing in that area of the launch map
Old Aug 6, 2012 | 11:58 PM
  #197
06RedRalli's Avatar
So for the launch map, should we be copying and using our current high octane ignition map into the launch map and then make our changes...
Old Aug 7, 2012 | 04:15 AM
  #198
211Ratsbud's Avatar
Yes
I can get about 10 psi but I can't figure out how to get any more
Old Aug 7, 2012 | 04:19 AM
  #199
kronik5383's Avatar
mine is not, but thats a simple way to do it. do not forget to adjust the fuel map as well
Old Aug 7, 2012 | 07:57 AM
  #200
Kakihara's Avatar
watch out what you copy/paste from the forums, I tried what was supposed to be a safe launch map giving only 17psi, slight retard+fuel
I press the clutch down, then the accelerator pedal, 0.9s later I have 29psi O_O, the turbo/engine did not like it and made worrying noises, evoscan later showed that I ended up in only a few seconds with 13knocksum, don't think I broke something but that was quite extreme
just be careful what you try
Old Aug 7, 2012 | 08:38 AM
  #201
211Ratsbud's Avatar
He was talking about copying his own hi octane map to start with
But I agree with not trying others maps lol..
I can't figure the trend out for timing arrangement myself. I'm using -20 up to about 130 load and tapering off by 180. If I add more negative timing it quickly adds knock. I have -20 on the rows above and below my fuel cut. Are you only supposed to have it below so when the motor accels to the fuel cut it has enough to increase rpms effectively?
Old Aug 7, 2012 | 08:43 AM
  #202
charlie.tunah's Avatar
to kakihara...please share this 29psi launch map! Im with 211ratsbud....>10psi would be sweet.
Old Aug 7, 2012 | 08:49 AM
  #203
211Ratsbud's Avatar
Yes I'd like to see the 29 psi launch map. I've gotten over 20 but not with out knock
Old Aug 7, 2012 | 08:57 AM
  #204
Ive never seen over 12 or so. But Ive also never gone below -10*. I know you have
Old Aug 7, 2012 | 09:10 AM
  #205
211Ratsbud's Avatar
Lol I had two barn fans cooling trying maps for an hour or so. 5250 is my rpm . Sat morning at 9 I practice
Old Aug 7, 2012 | 09:36 AM
  #206
awdordie's Avatar
No one should be copying in someone elses maps. Showing maps is only to give you an idea of how one should look when you are done. I can get 24 psi on my maps with the boost set at 26psi. The wg actually is cracked open and sounds ridiculous sitting still and almost sound.s like antilag.
The first thing you should do is log your current two step.
Next you will want to make changes in the areas slightly below and above rpm and load wise with fuel and timing. You will want to add alot more fuel in the areas below and above but it needs to be a smooth transition. I will post mine in a bit. 0 counts of knock on mine and the lowest timing is only -12 i think.
Old Aug 7, 2012 | 09:56 AM
  #207
06RedRalli's Avatar
Oh ya I'd never copy any one else's map. Just making sure I get started off on the right foot here.
Old Aug 7, 2012 | 10:36 AM
  #208
211Ratsbud's Avatar
Yea I have the smOoth transition down but obviously not where to put timing and fuel. I hold 180 load on two step . I'd like to figure out how to add more boost so I can decrease my rpms a little..
Old Aug 7, 2012 | 02:51 PM
  #209
211Ratsbud's Avatar
I'll post mine tonight
Old Aug 7, 2012 | 07:26 PM
  #210
211Ratsbud's Avatar
hopefully the resolution is decent. Im getting 10 psi with this map trying to build more. If I bring the timing ramp out it get knock, do I need to change the shape of the timing ramp once its on two step?
