launch maps
Old Aug 7, 2012 | 07:41 PM
  #211
Raptord's Avatar
I would try making it more gradual. Start dropping timing around 3500 or so.
Old Aug 8, 2012 | 03:39 AM
  #212
211Ratsbud's Avatar
I'd need to lower my tps threshold to get the switch over sooner . It's at like 20 now. I'll try it.
Old Aug 8, 2012 | 02:14 PM
  #213
211Ratsbud's Avatar
what is the relationship between cells that are hit while on ttwo step? I highlight my 180 load cell at 5000, and 5250. Should the 5000 180 load be of more negative timing than the 180 5250? so that when its fuel cutting down its getting more retarded and that when the fuel cut turns off and the motor accellerates briefly its increasing timing relative?
Old Aug 10, 2012 | 08:49 AM
  #214
diezilnj's Avatar
i gave the launch maps a shot and with -10* im building 18psi with my 35r. much better then the 5psi i was getting before. i took two videos but left the screenshots of my map on my other computer hopefully i remember to post that later.
Old Aug 10, 2012 | 01:52 PM
  #215
211Ratsbud's Avatar
Damn big turbo with a lot of launch boost
Old Aug 10, 2012 | 07:37 PM
  #216
211Ratsbud's Avatar
Any chance you can post the screenshot with the rpm your cut is set at? I have been doing a little more tuning tonight but the idea of where to place timing and fuel is still a blur. I cant get more than 9 to 10 on a stock frame turbo.
Old Aug 10, 2012 | 10:43 PM
  #217
211Ratsbud's Avatar
ok reviewed the first page. Went back to basics, gonna try from there. My increase decrease rpm vs timing idea was over thought because a lot of people are just doing blocks.
Old Sep 24, 2012 | 03:52 PM
  #218
Turbobudz's Avatar
Hi there men. New to the site as I've never posted before (due to never needing to ask a question as everything is covered here lol) but been reading alot. Im wondering would some1 be a kind enough to get me started on a launch map if i emailed them it please. Im just nervous. My first evo 8 and its EDM Thanks
Old Nov 23, 2012 | 09:39 AM
  #219
Macaroni's Avatar
Just made my own and first test shows 18.7 psi after just 1.3 seconds of being in it. No knock and smooth transition. I'm happy
Old Dec 1, 2012 | 01:21 PM
  #220
Lancer_Evo_8's Avatar
Here my new Launch Map with TephraV7, but for me still to much knocking. I have to check it again with EVOScan
The stat. rev. limit i have at 4000 U/min
Old Dec 1, 2012 | 04:40 PM
  #221
211Ratsbud's Avatar
What's your tps for launch maps?
Old Dec 1, 2012 | 11:24 PM
  #222
@ macaroni
Can you post your Launch Map?
Old Mar 10, 2013 | 11:28 PM
  #223
supasixfo's Avatar
ok, just started playing around with launch maps so bear with me.
I adapted raptord's -10 block, targetting 4500rpm stationary limit, and interlopolating up/down/all around.
used the fuel map from my high octane map.
Then i pulled some logs. From what i get out of it, i hit my -10 block, but from there all hell breaks loose. i am building boost 10psi-15psi.
you'll see from the graph, that's when i get 20+ counts of "knock". I think this knock is really just the backfire. as soon as the car starts moving, the knock goes away (on the graph). that said, the car bogs the heck down before transitioning to the high octane graph... i experimented with putting AFR to 10.0 in the fuel map and interlopolating, got similar results. what am i doing wrong here?
Time Seconds TPS RPM Ign Speed Knocksum
02:55.0 57.9168 51.7 4531.25 -10 0 1
02:55.2 58.11887 55.2 4531.25 -10 0 0
02:55.4 58.31894 73.7 4531.25 -10 0 6
02:55.6 58.51588 88.2 4500 -10 0 20
02:55.8 58.73292 100 4500 -10 0 33
02:56.0 58.92753 100 4000 -10 0 32
02:56.2 59.12962 100 2593.75 -10 0 32
02:56.4 59.32603 100 1750 4 0 0
02:56.6 59.54418 100 1562.5 8 6.21 0
02:56.8 59.73867 100 2250 6 6.21 0
02:57.0 59.93567 100 2187.5 5 6.21 0
Attached Thumbnails launch maps-revo_launchmap.jpg   launch maps-timing_vs_knocksum.png   launch maps-tps-engine-speed-knock.png
Old Mar 11, 2013 | 05:20 AM
  #224
Raptord's Avatar
I never actually launched my car with the launch maps I posted, I only made them to unleash the ricer that's hidden away inside me and see some flames , so my map may or may not actually work once you start moving.
Old Mar 11, 2013 | 10:12 AM
  #225
supasixfo's Avatar
lol gotcha - what have other folks done to deal with the knock issue? From the logs it looks like it'd be getting 10.0-11.3 AFR fuel wise. Given the load readings that are taken from the 1byte (though i'm not sure if they're accurate or how they are taken - 320 load on launch? is that normal?! i guess that could make sense with tps 100% rpm 4500, and boost between 10-20psi?)
is there a way to tell the system to ignore knock on launch?
