launch maps
Old Mar 30, 2010 | 12:55 PM
  #106
Seijuro's Avatar
Originally Posted by Skylineracer
the tephra mod v7 for 88590015 aka 88590715
Should be pretty cut and dry then, can you post your XML?
Actually put your ROM up too that way I can try to get it to display for me.
Old Mar 30, 2010 | 01:21 PM
  #107
iTune's Avatar
Oh yeah, my ROM is setup perfectly. I'm not testing this ignition timing retard from just the launch maps anyway. I've got -20deg in my main timing map, from 10-28% 2000-4000 rpm, 10-30% 4000-4750, 10-50% 5000-6000(so on and so forth)..... I usually run -10* in this area(for liftoff) and it pegs -10 everytime i lift. Dialed in -20* and it's still pegging -10 with the occasional(very occasional) -12-18* in one cell for a split second.
Originally Posted by Seijuro
Honestly, I didn't log it. I just gave it a test and it worked. There was a distinct difference between -10 and -20, so I didn't think about it any longer or even consider maybe it's not really at -20. I'll do a log tomorrow in the afternoon when less neighbors are home and see what my timing is like.
Here is how my ROM is set up currently.
You did enable Launch maps under the Tephra options right?
Picasa Fail, that's too small, here's a link.
http://picasaweb.google.com/lh/photo...eat=directlink
Old Mar 30, 2010 | 01:50 PM
  #108
Seijuro's Avatar
So I don't really have time to mess with it until this weekend probably, but I did a quick log this afternoon, and I am also showing timing at -10, not -20.
So I guess we're in the same boat.
Old May 4, 2010 | 10:53 AM
  #109
freshevo8's Avatar
Ok. Easier to find now....
Old Jun 24, 2010 | 11:17 AM
  #110
Gazika's Avatar
is there any tutorial for making launch map ? i tried to make similar map based on posted here but im getting 18-20 knocks , plz help or post your working maps
Old Jun 24, 2010 | 11:22 AM
  #111
ant_turbo's Avatar
Ya bump....
Old Jun 24, 2010 | 03:27 PM
  #112
VGergo's Avatar
How to get launch control like this ? http://www.youtube.com/watch?v=LRBHANh-_Yg
-10 degree timing retard is enough for it ?
Old Jun 24, 2010 | 06:36 PM
  #113
project_skyline's Avatar
Your putting in way too much fuel. That won' t transition that smoothly into the regular maps running that rich.
Old Jun 25, 2010 | 12:38 PM
  #114
ant_turbo's Avatar
My problem with the launch map is,, As I ease into the thorttle to active launch map boost is fine but!! as I get into the 2step and sit to long it makes high boost,,, Need to figur it out..
Old Jun 25, 2010 | 12:58 PM
  #115
Gazika's Avatar
someone plz post your launch maps
Old Jul 19, 2010 | 09:06 PM
  #116
D-VO's Avatar
I'm having trouble getting it to stay as steady as this one also. Is this the way -20 should sound?
Old Jul 19, 2010 | 10:40 PM
  #117
1slowassevo's Avatar
I played with mine on the weekend went from -20to-15 all different ways an my car didn't like it..finally I left it on -6with some 3extra fuel between 10.5to11.0and it builds 15psi with some loud poops and flames...it's crazy how cast it builds that boost and I'm on a very big Turbo.
Old Jul 19, 2010 | 10:47 PM
  #118
D-VO's Avatar
Yeah, I've got two cars (8 turbo and 9 turbo) that are building 22lbs fairly quickly, but they still don't sound as steady as the video posted.
Old Jul 19, 2010 | 11:27 PM
  #119
nonschlont's Avatar
if I remember correctly, the owner of that car stated he has some type of spereate launch control unit in the car to achieve that.
Old Jul 20, 2010 | 12:29 AM
  #120
D-VO's Avatar
??? Eh? It says "EVO 8 Tephra v7 Launch Map Test" as a title. Are you sure a bout that?
