new live map app
Old Nov 7, 2010 | 04:50 PM
  #226
golruss's Avatar
Originally Posted by ziad
But That should give you plenty of extra cash when you come back
Good one
Old Nov 9, 2010 | 08:53 PM
  #227
nitai3g's Avatar
Ziad I'd be glad to be another one of your testers.. i love the program and i'm currently using it to fine tune my car..its a eclipse 3g with evo 8 turbo bolt ones. the car is making about 300 to the wheels on my butt dyno.. but im not sure.. still fine tuning it.
Old Nov 9, 2010 | 10:15 PM
  #228
ziad's Avatar
send me a pm with ur email. i hope by start of next week you guys will have something (fingers crossed)
Old Nov 16, 2010 | 09:59 AM
  #229
JordanS4's Avatar
Ziad; I recieved your e-mail. I downloaded the old app to use on my IX with Stock ECU, Tephra 5.10 (would like to use v7), GM BCS, and Omni 4 Bar, but could not get it to work. I installed an alt-map switch in hopes of getting it to work but couldn't. I would test the new app if it would help but you may need to guide me step b step in setting it up. I read this thread but there is no definitive guide.
Old Nov 16, 2010 | 11:41 AM
  #230
ziad's Avatar
u need to have a livemap rom first.... and i am 99% sure there is no livemap rom for the usdm evo9.... only for the jdm9 (uk evo9). sorry
Old Nov 17, 2010 | 05:04 PM
  #231
JordanS4's Avatar
what? I have 88590015. That doesn't work? I used the ROM off your website, the one that says 88590015 v5.10.
Old Nov 18, 2010 | 11:34 AM
  #232
mt057's Avatar
bump an awesome thread. I wish we had this fo the 94170015. Makes me want to change over.
Old Nov 18, 2010 | 01:16 PM
  #233
ziad's Avatar
sending pm jordan
Old Nov 19, 2010 | 12:01 AM
  #234
nitai3g's Avatar
hey ziad. so i got everything running but its not reading any load. im running the 96532706 v7 rom.
Old Nov 19, 2010 | 04:38 PM
  #235
ziad's Avatar
What Do you mean not reading load......in the map tracer or the logger on screen or on your file.
Old Nov 21, 2010 | 08:23 AM
  #236
nitai3g's Avatar
yea the map tracer. when i rev the car is stays in the 10% load column and just goes to the rpm range that i hit but it wont go past 10% load.. im running 2byte load, in evoscan every thing is ok.
Old Nov 21, 2010 | 02:13 PM
  #237
ziad's Avatar
if the thing is logged properly then its the name... currently it uses some pre-defined combinations for load and rpm etc variables. if u use something else (And yes i might have used the wrong one in the standard XML given by the program) the map tracer etc wont work.
easiest currently is to rename the request to load.... or add one of the pre-defined 1-byte loads, at mut 41 or 0..... its called load too
Old Nov 21, 2010 | 02:16 PM
  #238
JordanS4's Avatar
sending pm jordan
responded, hit me on MSN
Old Nov 22, 2010 | 01:43 AM
  #239
Guru Johnson's Avatar
Any word on a 9417 build for this?
Old Nov 23, 2010 | 02:25 PM
  #240
ziad's Avatar
again i could be wrong..... but i dont think there is any modified rom for the 9417. the livemap stuff is the same as tephra mods. its a modified rom. someone has to do the modifications to the rom etc. seeing what happened with the USDM9 rom, where eric spent time to create one.... but no one has bothered testing it.... i doubt anyone will be willing to modify a 9417 rom.
saying that once a rom is modified, the livemap program can easily work with it.
