New thread for Speed Density tuning?...
Old Feb 6, 2010 | 07:31 AM
  #331
bigric09's Avatar
just to be clear...
If im logging the omni in evoscan and i am seeing -7 at vac, this would translate to roughly 51 kpa... and then when i see about 30 psi of boost, this should relate to 306 kpa ?
FYI, i log both zeitronix 5 bar boost sensor (which is the kavlico apparently) as well as the omni 4 bar.
I find that the omni does not show as much vac as the 5 bar, but when i do get in to boost they are dead on top of each other.
Old Feb 6, 2010 | 08:43 AM
  #332
l2r99gst's Avatar
Yep.
Old Feb 6, 2010 | 09:39 AM
  #333
bigric09's Avatar
thanks for responding...
I appreciate your help.
Now if i can get applaud or you or anyone with a better sense of editing these xmls... id like to be on the 88501715 instead of the modded 0715 that i am. Im still not all the way sure that i have all of the SD patches or configurations set correctly.
Old Feb 6, 2010 | 09:40 AM
  #334
bigric09's Avatar
Question...
When im on my SD rom, my idle is absolutely perfect.... if i unplug the MAF, i get a CEL as well as my idle will dip a little bit and the car idles, but its a little rough compared to on the MAF. Is there a setting i am missing somewhere ?
Old Feb 6, 2010 | 10:23 AM
  #335
l2r99gst's Avatar
Originally Posted by bigric09
Question...
Yep...sounds like you either aren't using an SD patched ROM or something in the SD path (if you patched yourself) is missing.
Old Feb 6, 2010 | 10:26 AM
  #336
bigric09's Avatar
i copied over everything from the jcsbanks thread into my 88590715 xml including the scaling settings for the omni. I havent seen anything else that i was suppose to copy into the xml. I thought about going into the 9653 sd rom and taking the asynch tables from there, but not sure if the addressing is the same and i didnt want to make things worse.
any ideas on why they would be missing or is/was there a separate thread originally with the asynch tables ?
Old Feb 6, 2010 | 10:30 AM
  #337
l2r99gst's Avatar
I'm not sure what you copied...maybe give us a link...but the aynch tables and such are just additional tuning tables.
You need the whole list of SD programming tables...the one's that are actually used to patch the ROM for SD (19 tables looking at my ROM here). Then you need to look at an already patched ROM and copy everything from those tables to the same tables in your ROM. The prepatched ROMs for download have these tables already set for you.
It sounds like maybe you tried patching yourself, but are missing these tables and you just copied the XML for the tuning tables?
Old Feb 6, 2010 | 10:41 AM
  #338
bigric09's Avatar
im showing 18 tables...
if you'd like i can email you my xml and current rom that is setup...
I just cant imagine what i missed. I copied everything from https://www.evolutionm.net/forums/ec...y-patches.html from the 88590015 xml that is downloaded, into my v7 xml.
i did notice that the maf cel table was set incorrectly on the rom. I just changed that and havent flashed to the car yet. I have to wait until this afternoon to continue testing.
Old Feb 6, 2010 | 10:44 AM
  #339
mrfred's Avatar
If you want wait another day, I'll be posting up a prepatched v7 SD ROM and XML to go with it.
Old Feb 6, 2010 | 10:46 AM
  #340
bigric09's Avatar
super...
Old Feb 6, 2010 | 10:47 AM
  #341
SyZyGy1394's Avatar
You should also put it in the tephra V7 thread.
Old Feb 6, 2010 | 11:12 AM
  #342
l2r99gst's Avatar
Did you start with a pre-patched ROM or did you use your ROM and then copy the patch over?
Just copying the XMLs do nothing but display the tables. If you are using your own ROM to start with, you still have to copy the settings from the patched ROM over to your ROM.
Old Feb 6, 2010 | 11:53 AM
  #343
bigric09's Avatar
i did that as well... sorry, should have mentioned that.
Old Feb 6, 2010 | 01:35 PM
  #344
bigric09's Avatar
Thanks to l2r99gst, im off the MAF now... thanks man. I went back to check my settings and i missed a couple of the tables that needed to have values changed. Flashed, let warm up, unplugged the MAF and no change in idle. Now i just have to do some fine tuning. My fuel map i think was off anyway.
Also, l2r99gst, as you suggested before about the omni kPa calculations.... I just went in to evoscan, created a new value to log, named it Omni kPa, put in this (1.632679*x) for the value and gave it the same request as the Omni Psi reference and now im logging both psi and kpa from the omni.
Again, i appreciate your help man.
Old Feb 6, 2010 | 02:16 PM
  #345
psphinx81's Avatar
to all the SD guys, where did you put the IAT sensor?
just trying to see where the most popular spot is.. IM or in the UICP
