New thread for Speed Density tuning?...
Old Feb 6, 2010 | 02:28 PM
  #346
mrfred's Avatar
Originally Posted by psphinx81
to all the SD guys, where did you put the IAT sensor?
just trying to see where the most popular spot is.. IM or in the UICP
The more technically correct location is the IM, but it requires R&Ring the IM. Much easier to install it in the UICP, but perhaps the air temp will be a bit cooler than in the IM. Mine is in the UICP.
Old Feb 6, 2010 | 03:07 PM
  #347
golruss's Avatar
Intake manifold....
Old Feb 6, 2010 | 06:10 PM
  #348
psphinx81's Avatar
do you guys weld in a bung in the IM?
Old Feb 6, 2010 | 06:12 PM
  #349
psphinx81's Avatar
going by this pic:
  #350
bigric09's Avatar
from the pics ive seen, drill and tap seems to be the method used
Old Feb 6, 2010 | 06:28 PM
  #351
logic's Avatar
That's exactly how I installed mine: drilled out the bung that's already conveniently located in the intake manifold (see the picture above), and tapped it.
Old Feb 6, 2010 | 06:33 PM
  #352
psphinx81's Avatar
thats why i asked, cuz i dont have that bung in my IM
Old Feb 6, 2010 | 06:40 PM
  #353
logic's Avatar
Aftermarket IM? If it's stock, that's really odd; would you be willing to take a picture of that part of the intake manifold?
Old Feb 6, 2010 | 06:45 PM
  #354
mrfred's Avatar
None of the USDM IMs have a bung. However, that location in the IM has an untapped flat (to the right of the circled MAP sensor). For the GM IAT, drill and tap for 3/8" NPT.
Old Feb 6, 2010 | 06:48 PM
  #355
psphinx81's Avatar
my bay for reference
Old Feb 6, 2010 | 06:57 PM
  #356
logic's Avatar
My apologies, I've been using the word "bung" to refer to that mounting location, and that's not quite right.
psphinx81, that's really strange; is that your original intake manifold, or one from another market?
  #357
mrfred's Avatar
huh. That's the stock IM? Had had assumed that all Evo's had that flat, but maybe its only on the IMs that correspond to the years when the JDM Evo 9 was manufactured (this is the location of the factory IAT sensor on JDM Evo 9s). At any rate, you'd need to remove the IM to tap it, so the solution is probably to find a used IM with the flat. Or there might be sufficient material to tap your IM.
Old Feb 6, 2010 | 07:18 PM
  #358
psphinx81's Avatar
that is not my orignal IM, it is jrods from buschur that he had on his evo before he sold it. its a ported stocker. its NOT a big deal if i cant put it in there, ill just put it in my UICP
edit: i just found a pic of my bone stock IM that i sold last year, it looks exactly like the one i have pictured above in my bay
Old Feb 6, 2010 | 07:31 PM
  #359
logic's Avatar
Hmm; you know, some of the Wilson manifolds I've seen (but not all of them) have looked like that, and here's another example of a stock manifold without the mounting location.
I wonder if this was just an '03 oddity?
Old Feb 6, 2010 | 07:37 PM
  #360
psphinx81's Avatar
lucky me, lol
