**Need Help setting up V7???** Here is your answer
Old Dec 20, 2009 | 06:20 PM
  #76
phenem's Avatar
In my modified ROM it is, but tephra does not change the stock ROM settings at all except for what he implements into his "mods"
Old Dec 20, 2009 | 07:08 PM
  #77
Appauldd's Avatar
So if we used your rom we should not have any boost limit ? ?
Old Dec 20, 2009 | 07:35 PM
  #78
phenem's Avatar
I do two things:
First I change the fuel (load) cut delay to 20000ms so it never looks at the load max, you will want to turn this back on to like 1000ms, which is stock if you want to use the boost/fuel cut.
Second, I max out the load on Fuel Cut to 319 which you would have to change to double load mod if you want enable this if you are above 319 load.
I don't recommend you leave it this way, I would fix it so it is tuned for your car's limit.
Old Dec 20, 2009 | 07:52 PM
  #79
Appauldd's Avatar
To be honest, I thought by using the "Fuel Cut Multiplier" I wouldn't hit fuel cut. I found out the other day that isn't the case.
I took your recommedations. Thank you.
Old Dec 20, 2009 | 08:20 PM
  #80
Evo_Jay's Avatar
Lol
Old Dec 20, 2009 | 08:23 PM
  #81
Appauldd's Avatar
We all have something to learn....to include humility.
Old Dec 20, 2009 | 09:17 PM
  #82
Evo_Jay's Avatar
I wasnt laughing at you. Sorry if it seemed that way.
You'll see why Im laughing in a week or so.
Old Dec 21, 2009 | 03:40 AM
  #83
And's Avatar
And
Originally Posted by And
HI can anyone help me, I'm having a small problem with upgrading to the tephra v7. I've managed to download the v7 original rom to the car and it started ok, (ran a little ruff) I then changed the immobilizer code and downloaded everything again and the car ran again, so I then copied all the maps from my old rom across but now it doesn't seem to want to start, I thought I'd managed to do everything correctly but must have done something can anyone offer a suggestion to what i've done? cheers Andy
bump any suggestions for this? thanks
Old Dec 21, 2009 | 07:50 AM
  #84
SWOLN's Avatar
Originally Posted by Fast_Freddie
Did you remember to disable boost cut in the V7 rom?
Load was at 319. I just set the "Boost Cut Delay" to a bazillion... For some reason I was thinking, with mrfreds Fuel cut x2, I didn't need to increase the ms on the delay. I was confused... I'll test it tonight, I hope it was a false alarm. Thanks to you, and others who replied on the subject.
Old Dec 21, 2009 | 07:54 AM
  #85
SWOLN's Avatar
Spill the beans...
Old Dec 21, 2009 | 10:56 AM
  #86
Evo_Jay's Avatar
Originally Posted by SWOLN
Spill the beans...
Be patient grasshopper
Old Dec 24, 2009 | 12:19 AM
  #87
rdtech's Avatar
If you disable the rear O2 via periphery bits, then that also disables fuel trims from reading FYI.
what is the correct way of disabling the rear o2 while leaving the fuel trim to be able to log? or would it have to just be turned on.
Old Dec 24, 2009 | 12:22 AM
  #88
rdtech's Avatar
Lets hope sooner. LOL. I cant wait
break bread.
Old Dec 24, 2009 | 09:19 AM
  #89
Fast_Freddie's Avatar
Veteran: Navy
There is a patch out now for the VIIIs that will allow you to simulate the rear O2 and the heater circuit, which should allow the fuel trims to operate...
https://www.evolutionm.net/forums/ec...r-circuit.html
Old Dec 24, 2009 | 09:58 AM
  #90
rdtech's Avatar
Great! Thanks FastLFreddie!
