94170715 V7 Issues
Old Dec 14, 2010 | 03:32 PM
  #271
tephra's Avatar
Can you post a log of RPM_SPEED_RATIO_AVERAGE + Gear
Just do a slow 1 -> 2 -> 3 -> 4 -> 5
that way we can see what its doing.
Old Dec 15, 2010 | 06:56 AM
  #272
AlexEvo6's Avatar
First, thanks for your help Tephra
You'll find attached the log you request.
I'll try to give you all the inputs
Settings in Evoscan:
<DataListItem DataLog="Y" Color="" Display="RPM_SPEED_RATIO_AVERAGE" LogReference="RPM_SPEED_RATIO_AVERAGE" RequestID="42" RequestID2="43" Eval="x/22.6" Unit="RPM/MPH" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Gear" LogReference="Gear" RequestID="40" Eval="x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="&#xD;&#xA;" Priority="1" Visible="False" />
RPM/SPEED to GEAR table (RPM/MPH for the ratio scaling) :
0 6
43.0088 5
61.9912 4
85 3
116.991 2
173.009 1
2899.78 0
I didn't catch exactly how does this work about the relation between gears and the ratio. Do you need an accurate value or these numbers are to be considered as defining a range between different gears ?
You'll find my current ROM here:
http://www.megaupload.com/?d=3NYSRCTD
Again, many thanks
File Type: zip
Old Dec 16, 2010 | 04:42 AM
  #273
tephra's Avatar
ok so your log is pretty good.
the values are slightly off.
I would use:
1st: 175
2nd: 120
3rd: 88
4th: 65
5th: 46
they shouldn't need to be super close, so im suprised its not cutting over properly...
Old Dec 16, 2010 | 04:43 PM
  #274
AlexEvo6's Avatar
Thx, I'll try these values tomorrow
EDIT problem solved with the values provided above.
Thanks a lot Tephra
I'm also quite surprised, in fact at the beginning I was considering these values as defining a range.
Def, I should be quite close !
Old Jun 18, 2011 | 12:17 PM
  #275
nonschlont's Avatar
bringin it back to life...
Have a buddy w/ an 03 VIII rom 94170008, his car is having some work done, and wants me to tune it when finished. Last night I loaded up the v7 rom on the car, I was gonna tune w/... (94170715 rom) just to see if it would take the new rom, and it was hunting for idle up and down... Being as tho, I was just testing to see if it would take, I just flashed back to the 08 rom... I would like to hook him up w/ all the goodies, so am looking for a lil insight...
My question is this, does the BISS need to be adjust when swapping from the 08 rom? I was under the impression, this was only necessary when swapping between USDM and EDM roms...
car has old s1 cams 1000cc inj. and full bolt ons.
Idle is @ 1k in all maps w/ the exception of the AC map which is @ 1200.
Disabled the warm up ignition maps.
rear 02 is disabled, altho Im gonna re-enable this and use tephras rear 02 sim.
Im willing to provide maps roms whatever...
Thanks
And Dave, your way OVER due for a donation from me, sir! But will be coming your way shortly...
Phil
Old Aug 6, 2012 | 12:43 PM
  #276
mll's Avatar
mll
Ok can anyone help me? I am having problems with the xml file for 94170715. It wont let me get to all of the maps. I called ecuflash they said that it is an xml problem. May if someone could direct me to a good working one or send it to me. Thank you all in addvance.
Old Sep 6, 2016 | 04:10 PM
  #277
dalys8's Avatar
Fuel cut / rev hang mystery
Can't get 94170715 to work. Above 5000 RPM's I seem to be hitting a fuel cut. I'm using PSI-based boost and I am nowhere reaching my PSI-targets before the supposed fuel cut is being implimented. Anyone willing to help, I am attaching my ROM and log of the behaior. Another thing to note is that my log of which gear I am in are completely off---not sure if that helps (all load or boost tables for each gear have some sort of target in it).
All tables switched over are from a perfectly working v5 ROM. I copied over MAF / ignition / fuel / boost / immobilizer etc. / periphery bits / the whole works. I have meticulously looked over every single setting in this ROM and cannot find any issues what-so-ever.
The issue is present whether I am PSI-based or Load-based.
I have attached a log of my v7 run that shows fuel cut at high RPM, a log of the working v5 ROM moving through gears 1-2, and my v7 ROM and .XML definition for review.
In summary:
-supposed fuel cut above 5000 RPM's
-gears logging wrong in EVOSCAN
Thanks to anybody that may be of help! I have been working to get things in order for over a month now.
You will notice my Boost Limit is set to low values, I had been messing around to see if that table changed the behavior if I set them high or low and I found no effect (except for getting boost cut, which is a totally different phenomenon from what I am experiencing).
Cheers,
-Shane
File Type: csv
File Type: csv
File Type: xml
File Type: bin
Old Dec 10, 2016 | 11:38 PM
  #278
Raceghost's Avatar
Did you ever get this figured out?
Old Dec 12, 2016 | 12:39 AM
  #279
mines5's Avatar
Any one getting P0121 and P0122 on this rom ?
Old Dec 14, 2016 | 02:53 PM
  #280
Evoryder's Avatar
not for me...you messed with your throttle body recently?
Old Dec 14, 2016 | 10:31 PM
  #281
mines5's Avatar
Not Really, just fitted Skunk 2 pro intake mani with a stock T.B .
Installed a TIAL Q bov with 10 Psi spring.
As soon as switched back to stock rom the P0121 and 122 are gone.
Checked for loose wires - Closed tp % 13.7 - fully opened 100%
Any suggestions please ?
Old Dec 19, 2016 | 09:29 PM
  #282
Evoryder's Avatar
why is it not at 0% when closed?
Old Dec 19, 2016 | 09:57 PM
  #283
mines5's Avatar
The stock settings are 13.7% anything lower than this , car's idle starts to drop.
Old Dec 20, 2016 | 02:07 AM
  #284
Raceghost's Avatar
Stock settings is like 11.5 to 12.5 depending on TPS sensor.
Mine is at 10.5 and fully opens to 100%. Does require a little Idle Set Screw adjust, but you should be adjusting it anyway to read 15 steps on the IAC.
Oh, and this is with Kelford 272 Cams, which is even harder.
But with stock cams, should not be that hard to set and get those Idle steps.
Old Dec 23, 2016 | 03:13 PM
  #285
Evoryder's Avatar
I haven't looked in a minute...been out the loop
