SpoolinUp SD plug-n-play harness development
Old Sep 27, 2010 | 05:56 PM
  #406
TK40's Avatar
Quick noob question for you guys. If I buy this harness do I still need the other parts that usually come in a put together SD kit?
Old Sep 27, 2010 | 06:14 PM
  #407
tweaker41's Avatar
Yes, the harness just makes everything converting to SD a plug n play system instead of having to tap into wires.
Old Sep 27, 2010 | 06:16 PM
  #408
TK40's Avatar
Thank you I'll be ordering one of these tomorrow!
Old Sep 27, 2010 | 06:30 PM
  #409
F0RSAKEN's Avatar
I may have missed it... But what exactly is the purpose of this harness? My car is running on SD right now, no spoolinup harness. What does it offer?
Edit: All I used was an Omni 4 bar. Nothing else... No wires spliced or anything.
Old Sep 28, 2010 | 06:54 AM
  #410
SpoolinUp's Avatar
Silver Sponsor
As for the baro, I need to dig back into that. I will probably just ship an adapter harness to MrFred as my ECUflash skills are minimal.
It makes the IAT painless to hook up.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Oct 17, 2010 | 03:58 AM
  #411
darwin_evo's Avatar
I assume using this harness means you will be using your maf iat wire as input for the temperature, NOT the fuel temp sensor, right?
Old Oct 17, 2010 | 06:40 AM
  #412
Evoryder's Avatar
Yes
Old Oct 17, 2010 | 07:54 AM
  #413
Walt's Avatar
If i buy the sd harness w/ IAT sensor does it come with a bung to weld on UICP?
Thanks
Walt
Old Oct 17, 2010 | 07:19 PM
  #414
evojon's Avatar
Got switched over to SD with ECU controlled boost via the GM 3 port solenoid today!! I'm using Matt's SD harness and BCS adapter harness as well. Awesome products, made the conversion in about fifteen minutes while Phenem was sitting in my car making up base rom maps.
I highly recommend going with Matt's harnesses, it's all pnp and is top quality. No worries anywhere. Spoolin up coil on plug is next on my wish list.
To be sure, Phenem did an awesome job road tuning my car. He took his time, explained everything along the way and was meticulous in his adjustments. His experence in SD tuning was apparant from the get go, there was not any gray areas. He knows what he's doing. Car idles smooth and pulls hard till red line. It's never been this smooth! If your in driving range of central PA, make the drive to get tuned by Phenem!!
Old Oct 17, 2010 | 07:44 PM
  #415
phenem's Avatar
John,
Thanks for the kind words! Glad you enjoy the car! Matt's stuff is def. top notch!
Old Oct 18, 2010 | 03:18 PM
  #416
SmurfZilla's Avatar
What would it take to get it done via email? LOL. I am struggling with having someone do it locally or or trying to find someone to do it remotely (brave enough). I'l already ECU controlled boost. Bought Matt's kit with the IAT sensor.....I don't think I need anything else.
DAmmit this is turning out to be more difficult then I thought. Waiting on a call back from Aaron at ER
Old Oct 18, 2010 | 06:25 PM
  #417
Evoryder's Avatar
What issues you having?
Old Nov 10, 2010 | 11:24 AM
  #418
mullen's Avatar
damn thats awesome i may have to hit him up on this sometime as its hard to find someone comfortable tuning cars running SD...
Old Nov 15, 2010 | 12:36 AM
  #419
leecavturbo's Avatar
the new custom moulded plug ready yet?
Old Nov 15, 2010 | 01:28 AM
  #420
addo's Avatar
I'm getting an SD map next week on a spare IX ecu, as previously mentioned what does this offer or it is a DIY sd map harness instead of remapping current non ecu map?
